Aux Fan Won't Turn Off!! - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 06-04-2005, 08:45 AM Thread Starter
fredo328's Avatar
fredo328 is an unknown quantity at this point
Send a message via Yahoo to fredo328
Whats this all about ? Anyone have any experience with this? Thanks
<img src='http://home.comcast.net/~farrieta/index_files/image001.jpg' border='0' alt='user posted image' />
<a href='
target='_blank'>328 life</a>
1998 328
fredo328 is offline
post #2 of 10 (permalink) Old 06-04-2005, 10:18 AM
quality
Delmarco's Avatar
Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute
What exactly happened? Were you driving for a long time? Were you working on the car?
Also a bunch of peoples have done the Fan Delete mod...try that...I think it adds HP or something as well.
Delmarco is offline
post #3 of 10 (permalink) Old 06-04-2005, 10:39 AM Thread Starter
fredo328's Avatar
yeah, I had just pulled in from a 5 hour road trip. Heard the fan running after I got out of the car, went back to the car a couple of hours later and it was still running so I pulled the fuse. Put it back in this morning and it kicked back on again.
<a href='
1998 328
fredo328 is offline
post #4 of 10 (permalink) Old 06-04-2005, 10:55 AM
quality
Delmarco's Avatar
Unplug the battery.
Or try and stop it with your fingers (no joke) and see if it starts back up again.
Delmarco is offline
post #5 of 10 (permalink) Old 06-04-2005, 01:26 PM
Gator is an unknown quantity at this point
There is a temperature sensor screwed into the bottom of the radiator which most likely needs to be replaced. Remove the leads and with the car cold, check the continuity between the two electrical connectors on the sensor. There should be no continuity. If there is the sensor is bad.
Gator is offline
post #6 of 10 (permalink) Old 06-04-2005, 01:54 PM Thread Starter
fredo328's Avatar
I was thinking that was it, I think on mine, though, the DOUBLE TEMPERATURE SWITCH is on passenger side of the radiator.
<a href='
1998 328
fredo328 is offline
post #7 of 10 (permalink) Old 06-04-2005, 02:32 PM Thread Starter
fredo328's Avatar
It is on the side. I took it off and cleaned it and the connections not really anticipating anything would happen. Well now it works like it should. Comes on with the A/C and turns off when shut off car.
<a href='
1998 328
fredo328 is offline
post #8 of 10 (permalink) Old 06-04-2005, 02:53 PM
ollyh1973 is an unknown quantity at this point
[snapback]350730[/snapback]
I have the same problem on my 323 E46, I will try the same.
Do you have a more detailed description of what you did?
Thanks
ollyh1973 is offline
post #9 of 10 (permalink) Old 06-05-2005, 09:15 AM
post #10 of 10 (permalink) Old 06-05-2005, 09:54 AM Thread Starter
fredo328's Avatar
Mind you this may not have fixed my problem but so far it has, will know for sure after my 5 hour road trip back home today.
On the passenger side of the radiator toward the top is a double temperature sensor with a wire running out of it. I figured I needed to replace that but before doing so I unplugged it and cleaned it and the connections and now it works. I figure its on its way out and this is just a temp fix but we'll see, at least I'll be home. Hope that helps
<a href='
1998 328
fredo328 is offline
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 03:18 PM
Auxilary Fan (won't Turn On) / R-145a vmelikRUS 3-Series (E36) 6 05-03-2005 11:41 AM
Windshield Wipers Won't Turn Off rotaryrex7 3-Series (E36) 2 03-14-2005 09:43 PM
Windshield Wipers Won't Turn Off rotaryrex7 3-Series (E36) 2 10-23-2004 02:09 AM
Odd Noise? Won't turn over? kraze0g 3-Series (E36) 4 08-12-2004 01:47 PM
