| PB Blaster. Go pick some up from your local hardware store and spray it on there. Then get the longest wrench you can fit in there and turn the sucker out. If need be use a large for more leverage. If it's a tight space you might only be able to move a tiny bit. But once it's lose you can put the impact wrench on it.
Kevin
"WAAAAAAARRRRRIORS, come out to plaaaaay." |
