Anyone Put M3 Front Brakes On A 325i? - BMW Forum - BimmerWerkz.com
Old 03-30-2005, 06:25 PM   #1 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
my brakes are goin out, calipers are stickin, and instead of a rebuild kit, i might want to get some M3 calipers and cross drilled rotors. Do the M3 calipers just bolt on to the same location as the 325i does or do you need to buy additional brackets? if so where can i get them.
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 03-30-2005, 06:39 PM   #2 (permalink)
meph's Avatar
meph is an unknown quantity at this point
Send a message via MSN to meph
[snapback]321851[/snapback]
Bolt on
Just to get you thinking... E32 750 brakes would be even cooler They are bolt on too. E32 starting from 91' have 324x30mm rotors and four piston calipers
Thinkin about doing that myself during the next year or so... But I'd suggest upgrading back brakes too, else you could screw up your brake bias. Also, if you're going to use 750 brakes you may need to change you brake master cylinder.
Just a few thoughts.
<img src='http://meph.pri.ee/~meph/sig.jpg' border='0' alt='user posted image' />
<span style='font-family:Arial'><span style='font-size:8pt;line-height:100%'><span style='color:green'><a href='http://www.clubarena.com/~bmwklubi/gallery/album32' target='_blank'>My car</a></span></span></span>
(Started as a 316... not anymore)
Custom leather interior, custom audio install, custom made bumpers, clear side and corner markers.
Custom exhaust, CAI (also custom =) )
M50B25 transplant, 325 brake system, brembo rotors, ferodo pads.
Coming:
Coilover kit, 17'' rims, lots of gauges and a few surprises.
meph is offline   Reply With Quote
Old 03-30-2005, 08:23 PM   #3 (permalink)
I'll look into that. sounds like a good alternative.
325i Front Brakes M3wannabe2004 3-Series (E36) 1 09-11-2005 01:49 PM
Cont Arms, Wheel Well, Front Brakes netgeek 3-Series (E46, E90) 8 08-26-2005 07:12 PM
Front Brakes 93 325i 3-Series (E36) 13 01-04-2005 05:31 PM
Brakes: Cost For Front And Rear? DrewsBlues 5-Series (E12,E28, E34, E39, E60) 6 11-17-2004 11:07 AM
New Front Brakes... doughboyea 3-Series (E46, E90) 8 08-19-2004 12:19 PM
