Anyone Had This Problem? - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 06-08-2005, 10:13 PM Thread Starter
bkcraun is an unknown quantity at this point
1992 E36 325i, check engine light comes on, idle starts surging. I changed the ICV and nothing changed. I changed the O2 sensor and the check engine light and the idle surge went away! Problem solved........except. I have now done this "fix" on 3 separate occasions over the last 6 months. Each time it solves the problem, but each time the problem eventually comes back. No codes other than something isn't reading the O2 sensor. What is it?
bkcraun is offline
post #2 of 3 (permalink) Old 06-09-2005, 02:01 AM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
What code exactly are you talking about?... If your not reading your O2 sensor.. there are ways to check the electrical validity of the O2 sensor... which makes sure its sending back the right signals... (checking the O2 sensor it self) If your not getting the signals back to the ecu... the only thing I can think of is you have a problem with the connection line between the O2 sensor and your computer system.
I was start small.. and work up... since replacing the O2 sensor fixes this problem... try keeping the O2 sensor.. and changing the wiring harness... you can get one online or at the dealer. See if that fixes her...
Good Luck... and I hope this either helps or points you in the right direction.
Lers
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #3 of 3 (permalink) Old 06-09-2005, 02:01 AM
Been here a while.
97alpineM3's Avatar
Les
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 1 04-01-2017 04:54 PM
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
Alpine 9835 Fm Tuner Problem ultraviolet353 Audio and Electronics 7 09-22-2004 11:09 PM
