Anyone else have problems with brake lights? - BMW Forum - BimmerWerkz.com
Old 06-10-2004, 09:54 AM   #1 (permalink)
jroberts312 is an unknown quantity at this point
ghead
I have never had so much trouble with brake lights since I bought my 318I. Every month it seems, either the driver or passenger side light goes out. The socket seems to get loose and just wiggling it causes it to work again. Is it me or is this the worst design yet? I have made sure the socket is in properly and snug. I have even cleaned the contacts to make sure it doesn't happen again. It still continues to occur. I once replaced one of the sockets because it quit working altogether. Anyone else having this nagging issue? Is there a nice trick to get them to fit better?
jroberts312 is offline   Reply With Quote
Old 06-10-2004, 10:23 AM   #2 (permalink)
mrjoshua's Avatar
mrjoshua is an unknown quantity at this point
Send a message via AIM to mrjoshua Send a message via Yahoo to mrjoshua
I was having this same problem, so I just took some electrical tape and put a little piece on either side of the bulb on the plastic. This should keep it in there snuggly, as well as, allow the connections to touch. Hope this helps.
mrjoshua is offline   Reply With Quote
Old 06-10-2004, 11:35 AM   #3 (permalink)
CR320i's Avatar
CR320i is an unknown quantity at this point
Send a message via MSN to CR320i Send a message via Yahoo to CR320i
this is what happened yesterday evening:
one of my front fog lites was not working, I bought the bulb and replaced the wires for another.
On the rear or tail lites there are two lights that work if your fog lihts are on.
Only one of this is working, the left one.
Then we, my dad and I, attempt to fix this, but we messed up.
Now i dont have reverse signal, and if I turn on the signat --> two lites are blinking on the left side, the midle one and the signal lite itself, this is a mess.
We tried to undo all but is worst.
The signal --> in the dash panel now blinks delayed.
Help!!
E30
1985/320i
german version
CR320i is offline   Reply With Quote
Old 06-10-2004, 12:28 PM   #4 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
Go to your local BMW dealership, and you can get a new bulb socket. Sometimes with the turn signal problem, you have to make sure the bulb socket is in correctly.
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Old 06-10-2004, 06:01 PM   #5 (permalink)
Defector
El Presidente's Avatar
Have you checked to make sure the lights are secured in place? There are 4 nuts on the back of it; make sure they are tight.
Old 06-11-2004, 10:03 AM   #6 (permalink)
trinidon2k's Avatar
trinidon2k is an unknown quantity at this point
Send a message via AIM to trinidon2k
niether of my breaklights work... ..i just rely on my spoiler break light and rear window break light....everytime i tighten it it just gets slack again....i guess i should put some electrical tape or something.....as far as i can see....almost all e36's have problems with the break lights....especially the drivers side....i'd say 40% of the time that i see an e36 on the road the break light is out
trinidon2k is offline   Reply With Quote
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
ABS, brake, and ASC warning lights on!? mantoboy 3-Series (E46, E90) 9 02-09-2009 06:54 PM
Brake Lights Stay On Nealdavis4 3-Series (E21, E30) 0 12-17-2004 01:21 AM
Brake Lights Failure, Now. bkstaylor 3-Series (E36) 1 11-24-2004 09:45 AM
