I'm running 225/45/17's all around right now on a ACS Type I 17x8 rim ET35. I want to run 235/40/17 rear and 225/45/17 front. I know this obviously increases a bit of understeer, but the question is, how much? Will it be enough to notice a difference? What will high speed statability be like? Any negative side affects?
I actually want a bit more understeer as my rear end feels a bit too twitchy. I want the rear end more firmly planted for track driving.
Any help greatly appreciated. I'm using Dunlop SP's.
Originally posted by JAX@Nov 19 2004, 02:03 PM Had something like this on my E30.
Could not feel any real difference but the car looks better.
[snapback]233922[/snapback]
I guess it would be hard to tell the difference without going on a track, but I'm very picky when it comes to these things. I know how my car handles too well so any change in handling I would notice. What tire sizes were you using?
thanks,
Bry
I'd also like to point out that I do not know why I'm posting.
note: I'd also like to point out that I'm dead wrong and they are only an inch wider in the back.
Why not go 235 all around so you can still rotate them. Once you get the DASC you might be going through back tires faster than you want.
Do you have the rear sway set all the way to soft? What are your aligment specs maybe you could have them throw a little more/less camber on the rear to hook up better around the corner.
What's with you guys and rotating tires? The front and rear -ve camber differs by too much. I never rotate my front and rear tires nor are you even supposed to. I'm not doing this for looks, I want my rear end to be more firmly planted as I mentioned before I feel like the rear is a bit too twitchy.
M3's were pretty much designed to work with the staggered setup and I'm sure all that extra torque makes up for any noticeable understeer, if any at all.
BTW, tire prices for 225 and 235 only differ by $8. I need to replace my rears next summer so I figure I'd try it out. Just wondering if I'd get excessive understeer.
Thanks guys,
Bry
Originally posted by Autotechnica@Nov 20 2004, 12:16 AM The front and rear -ve camber differs by too much. I never rotate my front and rear tires nor are you even supposed to.
[snapback]234170[/snapback]
That's assuming you've got a factory alignment... I don't know why other people are swapping the tires, but I swap front to back before each auto-x so I don't have to replace the rears before the fronts.
I'd consider my situation to be a little different then the average driver. Why so against the rotating? Maybe if you'd swapped the front to back a few times you wouldn't be replacing the back tires only. :nana
Cruzin- I refer you to Auto's 'mod list' in his sig
Originally posted by Autotechnica@Nov 19 2004, 11:16 PM What's with you guys and rotating tires? The front and rear -ve camber differs by too much. I never rotate my front and rear tires nor are you even supposed to. I'm not doing this for looks, I want my rear end to be more firmly planted as I mentioned before I feel like the rear is a bit too twitchy.
Thanks guys,
Bry
i use to work at a tire shop and the camber alinement is not why you rotate tires its mainly cause if you dont rotate them the tire will chop( looks like waves on tire) causing road noise and premature wear and sometimes vibration. i would say to replace a suspension parts on the back with per. parts to get your added traction you want. but thats just me
bry i run 235 all round and its fine. but i think staggered that little will be no real noticeable differeance. i guess the only thing you would notice is a bit of understeer.
Hey Bry: I don't rotate either. Don't see any reason in it. On our cars the tire wear differs (front to back), so rotating "ain't" a great idea, your right.
As for staggering, with that little of difference, you won't notice anything, I promise. You also don't have to do anything as drastic as 215/265 either.
I haven't played around with tires on this car yet, but when I order new shoes in the coming weeks, I'm going with 235 up front and 255 out back. I just like a bigger contact patch back there, and a certain amount of predictable understeer is what I like. I'm certain I won't feel much (if any) difference from what I have now (235 all around), but this just seems like a good set up for me.
