another sunroof question...tap motor it works again... - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 07-26-2013, 02:39 PM Thread Starter
snyper is on a distinguished road
well two things here, first off my first ever post..and my first ever BMW (325is)..
now my question...i been fixing little things here and there but now i have a question about the sunroof..and YES i searched this and many other sites..
ok question-- my sunroof seems to work intermingling, BUT, if i bang on the sunroof motor or tap the motor it will then open and shut again (and tilt) but after a few minutes returns to not working..hit it again...works again...
can i take apart the motor and clean and lube it? or is it a replace only fix...???
thanks in advance for any and all help...
snyper is offline
post #2 of 7 (permalink) Old 07-26-2013, 06:47 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 2 Post(s)
What year is your 325? It could be that a wire to the motor has come loose or has frayed and is shorting out. I would start by checking that first. The hitting it could be causing the connector to connect enough to get power for a short period of time.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
post #3 of 7 (permalink) Old 07-26-2013, 08:57 PM Thread Starter
yeah i guess i should have stated year..its a 1995. i took off panel cover and have it hanging down...been working fine, put it back up it freaks out again. thank you for the suggestion, first thing in the morning im going to pull it into the garage and check the wires as you suggested.
have a few other things wrong with it as well, but i will try to fix them first before asking.
thanks again my friend.
1995 325 is black 2 door, 1999 M3 silver
snyper is offline
post #4 of 7 (permalink) Old 07-30-2013, 10:33 PM Thread Starter
hey thanks guys, turn out one of the connections was loose inside one of the connectors. easy fix and i didnt have to but another SR motor. now im fixing PS recliner and PS window wont work...cant seem to get cruise control to work either. dont have a manual so not sure if im trying to turn it on properly.
snyper is offline
post #5 of 7 (permalink) Old 08-02-2013, 10:53 AM
4DoorWhore
Lord Vader's Avatar
Quoted: 2 Post(s)
The cruise control has a seperate module located in the engine bay that connects to the throttle body. Its located next to the airbox on the drivers side wheel arch. I have one for sale depending on where you are located.
For the windows, check your fuses. The window motor or regulator may have failed.
post #6 of 7 (permalink) Old 08-02-2013, 11:19 PM Thread Starter
I think I found it. Kinda looks like a mini data port. It sits I n fender well and if you unscrew it it has pens.
I found something. It looks like vacuum lines with a sensor attacked to it. It's F shaped. Two lines going into a sensor of some type. What is that? Previous owner just has it hanging down. The two hoses plugged into it but the sensor is just going nowhere.
Pm me price for cc...I live in 21901 zip
snyper is offline
post #7 of 7 (permalink) Old 08-15-2013, 01:59 AM Thread Starter
OK so fixed sunroof. Junkyard has a bunch of bimmers. Changed motor from a 97 e36 into mine...sunroof works flawless.
snyper is offline
2003 330xi sunroof motor reece3223 3-Series (E46, E90) 2 09-03-2012 09:03 PM
My sunroof works..... sometimes Fash 3-Series (E36) 1 06-05-2004 07:24 AM
NEW SUNROOF MOTOR INSTALL! M5power 5-Series (E12,E28, E34, E39, E60) 1 04-26-2004 12:34 PM
