Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 04-19-2005, 01:08 PM   #1 (permalink)
Photos: 0
scorn6 is an unknown quantity at this point
I've been meticulously restoring, upgrading & maintaining a 94 325is w/ 130K since this past September. Ever since I purchased this car I've been plagued with an incessant engine rattle which seems to stem from one of the external components mounted on the front of the motor. It only rattles during idle mode and will halt at the slightest RPM increase which leads me to believe that it is surely belt-drive related. However, a check of all belt driven components shows everything tight and in proper working order.
I've changed the belt along with the idler pulley but am reluctant to to change any additional componenets due to the fact that they are all working properly and a trial and error check could turn out to be a complete waste of money. I'm a hard core DIY'er but simply loath the thought of having to take it to a shop.
Anyone else here had a similar issue in the past or any reasonable suggestions? This is really driving me nuts.
Regards,
scorn6
scorn6 is offline   Reply With Quote
Old 04-19-2005, 04:47 PM   #2 (permalink)
Photos: 0
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
My 96 Impala SS's belt tensioner bearings would go every 10K.
This is actually do in fact to a slight misaligment GM made when they designed the alternator brackets...... Thats GM for ya! :P
The bearings would go premature... but the sound was masked by the chirping noise the belt would start making. The GM dealer would always replace the tensioner and the belts to remove the problem under warrenty.
I doubt you are having the same problem, but perhaps my little story will give you some new trains of thought on the matter.
Good luck
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 04-19-2005, 04:54 PM   #3 (permalink)
ridikuledind's Avatar
Photos: 0
ridikuledind has a little shameless behaviour in the past
Mine does that same thing and i cant figure out what it is. I changed all of my belts and all of the pully's, but the noise wont go away. I also changed the clutch fan because i thought that might fix it, but it didnt. if you figure it out let me know because i think it makes my car sound like crap...when its ideling.
<span style='color:red'><span style='font-size:14pt;line-height:100%'><span style='font-family:Geneva'>&quot;Were coming for you&quot;</span></span></span>
ridikuledind is offline   Reply With Quote
Old 04-20-2005, 10:34 AM   #4 (permalink)
93 325i's Avatar
Photos: 0
By the description i'd say VANOS. The location of the sound is right and I know a VANOS makes a rattling sound when it gets worn.
Complete mod list and pics:
My 1993 325i
Old 04-20-2005, 12:04 PM   #5 (permalink)
7th Gear (SMG)
Photos: 0
A longshot - it may be the brake calipers. Granted, not on the engine, but they are in front of it. These could rattle at idle.
1998 BMW e36 M3 Sedan
2003 MINI Cooper
Old 04-20-2005, 01:34 PM   #6 (permalink)
Photos: 0
vincentwashere is an unknown quantity at this point
Send a message via AIM to vincentwashere
[snapback]335320[/snapback]
agreed. its either rattling or ticking. u can hear it right above the fan. its rather expensive to fix. the unit was 200 dollars with discount at dealer, and 700 for labor. please do not replace it yourself if u dont have the special bmw tools. my friend did that and he almost had to buy new cams and shit. and his compression was all funkd up
<img src='http://pic15.picturetrail.com/VOL615/2358567/4641837/67358906.jpg' border='0' alt='user posted image' />
vincentwashere is offline   Reply With Quote
Old 04-20-2005, 10:17 PM   #7 (permalink)
Photos: 0
Whats the VANOS?
vB code is On
'02 318 Idle / 1500rpm Engine Rattle matrhos 3-Series (E46, E90) 3 09-03-2005 10:32 AM
Any Issue For Putting Obd I M3 Engine In 325i? r6bruin 3-Series (E36) 2 08-13-2005 08:12 AM
Annoying check engine and lighting problems Skipjacks M-Series (M3, M5, M6) 1 08-30-2004 11:01 AM
BMW P83 Engine triggrhaapi Bimmer Talk/Motorsports Talk 0 07-21-2003 03:03 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
