Alternator belt tension - BMW Forum - BimmerWerkz.com
Old 09-05-2004, 02:26 AM   #1 (permalink)
Spook's Avatar
Spook is an unknown quantity at this point
This is likely a stupid question, but here goes...hehe
How do you know when you've gotten the "correct" tension on the alternator belt, and what is the best method for this?
I'm changing mine in the morning (alternator and the belt), and after reading the FAQs I found on the forums I'm fairly certain of how it all goes except for the tension bit (I don't have the automatic tensioners). I've only ever changed alternators on old VW Bettles and an '83 Malibu (stop laughing, they were good to me...lol), so the above is of concern.
Thanks in advance!
Spook is offline   Reply With Quote
Old 09-05-2004, 07:24 AM   #2 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
you don't want it to loose but ya don't want it to tight, you know that, best idea is to tighten down a little past where you think and back it out untill there is some movement when you push on the belt but it isn't loose
getting it a little to tight isn't a real problem but it will wear the belt faster
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 09-05-2004, 01:03 PM   #3 (permalink)
Spook's Avatar
Thanks, Teg...That's about what I was thinking.
Old 09-05-2004, 02:58 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
As long as it dosn't slip at all, and isn't too tight where the belt will break pre-maturely...
Old 09-05-2004, 03:14 PM   #5 (permalink)
Spook's Avatar
Thanks...I was outside pulling the old one off her when it started raining hard...lol I think I can track what you guys are saying, though, so it should be all good.
Old 09-05-2004, 09:59 PM   #6 (permalink)
Speedy-325is's Avatar
~*Teg*~
is that the technical explanation????
just leave about 1/2 inch of play in the belt. it will be fine.
Mark
Old 09-05-2004, 10:45 PM   #7 (permalink)
Spook's Avatar
Thanks all...I got it put in okay (between the rains...hehe). I'll be getting an oil change Tuesday, and will have the mechanic check to be sure all is well; I have between 1/4 and 1/2 an inch of play on the belt, and it turns the alternator pulley, so it should be fine. Tomorrow I get to clean the ICV...Fun, fun (trying to track down uneven idle).
