Originally posted by jimma@Aug 16 2005, 12:46 PM yea i replaced the battery and i ran new wires for grounds they were old but it still does not work im hopping i didnt fry the computer [snapback]369964[/snapback] |
I dont want to scare you, but if you reach 17v that is enought to fry 12v circuitry,
Altouhg most electronic car computers will sustain such voltages. Look for some relay. BMW uses bosch diode relay, they are designed so that they will not work if there is reverse polarity or high voltage. Most likely you fried the DME Relay together with some other main relays, look for burn fuses, and relays.
Hope this helps.
