All kinds of technical problems... - BMW Forum - BimmerWerkz.com
Old 05-28-2004, 01:13 PM   #1 (permalink)
FederalAuditor is an unknown quantity at this point
Problem 1: I came back to my car yesterday and I heard a beeping noise. But this isn't the typical Memo, limit or timer beep. The damned thing beeps continuously and doesn't turn off. The only time it stops is when I have the door open... at which time it makes the usual "door open" chime, but as soon as the door is closed, it starts beeping again. For the time being I've unplugged the speaker under the steering colunm until I figure out what it is. Now given that my OBC says that its -37C all the time, it may be the cold temp warning, but the temp has always read -37 and never caused the beeping before.
Problem 2: When I make right had turns, I hear this awful clunking/heavy grinding noise, it sounds like its coming from the back, but I can't but positive as I can feel the vibration at my feet. It doesn't sound quite as bad when I'm not on the gas through a turn, but is sometimes still evident. Everything sounds normal when I'm making a left. Could it be play in the driveshaft?
Problem 3: When I start my car on a cold morning, the idle bounces around like crazy. In hot weather, the idle drops extremely low... and ocassionally causes the car to stall. There is a CEL being thrown, be it comes and goes as the idle bounces around. I've been told that it might be the AIC valve might be stuck. Also, when I give the car gas and the rpm's go back to Idle, I'll hear a hissing noise. Might this be a vacuum leak?
The last time I posted here, I got a lot of help... so I'm back for more. Thanks in advance for your time.
J.
FederalAuditor is offline   Reply With Quote
Old 05-28-2004, 04:30 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
J.
1- i think maybe there is a problem with your OBC or temp sensor, i cant remember what the american warning is but at +3 or -3 celcuis the chime dings.
2- sounds like a wheel bearing or it could be a guibo disk,
3-this last problem can be a few different things, could be a problem with the MAF, or the idle control valve or maybe . when was the last tuneup you did?
Old 05-28-2004, 04:39 PM   #3 (permalink)
Car: 2008 128i
try replacing the temp sensor.
be sure you don't have like the speed on the obc. when ever you travel at that speed you get a beep from it. its very damn annoying.
2008 128i Jetblack
Climate Control Problems black318 3-Series (E36) 0 02-24-2005 02:00 AM
E36 (1995 325i) Technical Problems bimmer_boy 3-Series (E36) 5 04-05-2004 03:03 AM
