Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 03-13-2006, 01:44 PM   #1 (permalink)
TeeUp's Avatar
Photos: 0
TeeUp is an unknown quantity at this point
Alignment Q's
my baby tends to swerve right on the freeway. i was thinkin maybe its my alignment.
i understand e36s use a weighted alignment system where it has to be loaded with proper weights prior to alignment. (p272 bentley.pdf) - something that goodyear, pepboys, les schwab admit they're not equipped to do.
any quick checks before i write a $250++ check to the stealership?
TeeUp is offline   Reply With Quote
Old 03-13-2006, 02:26 PM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
Photos: 0
damn, an alignment costs 250 bucks at the dealer.... DAMNNNN...
my mechanic charges 75 bucks, and i thought that was bad...
-SOLD..
R.I.P Fast 6
Old 03-13-2006, 03:14 PM   #3 (permalink)
Big Pimpin'
SpeedInfusion's Avatar
Car: ///M3,Corolla
Photos: 0
wait wait wait, sounds wrong for some reason, are u using the stock suspension?
Old 03-13-2006, 04:07 PM   #4 (permalink)
TeeUp's Avatar
Photos: 0
yep. all stock. but i take back les schwab. they'll do it for $75.
Old 03-13-2006, 04:15 PM   #5 (permalink)
TeeUp's Avatar
Photos: 0
called up another dealership. they said they'll charge $140.
Old 03-13-2006, 06:24 PM   #6 (permalink)
Photos: 0
Dealers are crap...
The dealership will most likely do the exact same thing any of the other shops will do, except double the price. Find a shop locally that uses a Hunter laser alignment system. Offer to sit in the car while they do it and see if that changes any of the numbers, probably not. The Hunter system compensates for no passengers in the vehicle. Hunter Computer Laser Alignment Systems
Mike
Hamfisted is offline   Reply With Quote
Old 03-13-2006, 08:31 PM   #7 (permalink)
Big Pimpin'
Car: ///M3,Corolla
Photos: 0
u dont need a dealer......around 70 is right
Old 03-15-2006, 09:52 PM   #8 (permalink)
Masse's Avatar
Photos: 0
Masse is on a distinguished road
Send a message via Yahoo to Masse
32 00 Wheel Alignment - Normal Position / Inspection Conditions E36 / E38 / E39
Car loaded down to normal position Vehicle with complete equipment for normal operation with:
2 x 68 kg on front seats (seats in central position)
1 x 68 kg on rear seat (center)
1 x 21 kg in luggage compartment (middle)
and full fuel tank.
Exception:
M3 sports suspension
Normal position for car empty weight
Requirements:
1. Specified rims and tires with even tire profile (see Wheels/Tires)
2. Correct tire pressure (refer to instruction plate on vehicle)
3. Specified wheel-bearing play (see Front/Rear Axle)
4. Ride level check in normal position (see above) Ride level measurement, refer to Repair Manual 31 33 095 Warning! Repair vehicle in event of deviation from specified value (refer to Troubleshooting Repair Manual)
5. On car with air springs, pull fuse of air supply system so that there is no regulation.
Adjust correct ride level for alignment = spec. value ± 2mm /
for E 36 M 3, E39 M5, E39 with M sports package
spec. value ± 1mm
by loading or unloading car.
These are the requirements for an alignment straight from BMW.
You can have some hack that does alignments at an independant shop mess up your BMW for 70.00, ore you can take it to the dealer and have someone who is trained to work on a BMW correctly adjyst your alignment for 170.00.
ist up to you. I would spend the extra money and know the job was done right.
Masse is offline   Reply With Quote
Old 03-16-2006, 01:29 AM   #9 (permalink)
WarNox's Avatar
Photos: 0
i dont think u'll notice a difference, what do those weights achieve? as long as the car's going straight when u let go of the steering wheel on a straigh road its fine!
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 03-16-2006, 09:01 PM   #10 (permalink)
TeeUp's Avatar
Photos: 0
what makes a car pull to either side (mine is to the right)?
toe, camber, caster?
i understand that e36s only the front toe-in can be adjusted. the rear toe as well as the camber and caster (front and back) are fixed by designed and can only be altered if the suspension parts are worn or messed up.
we'd actually end up paying $170 or so at the dealership just fixing the front toe. i think that is indeed a little too much.
Old 03-17-2006, 08:39 AM   #11 (permalink)
Threadkiller
bitcore's Avatar
Photos: 0
toe.
tie-rods control this in the front
rear trailing arm console controls this in the rear - which the wheel is connected to the frame by the bushing-through the console. Be sure the bushing & your tie rods are good before you even THINK about getting an alignment. Cause, if your suspension dosn't HOLD the alignment, it's *USELESS*
Yes, you can change the rear toe, anyone who tells you otherwise shouldn't work on the car
Extreme camber can do this too, but you would SEE that it's off and it wouldn't be balenced from side to side. Look at the back wheels from the back of the car, see how the top leans outwards? that's camber (if they dont, your not looking at it right or your lower control arms are bent). Some negative camber (which is top out, bottom in) is GOOD.
Old 03-24-2006, 12:42 PM   #12 (permalink)
TeeUp's Avatar
Photos: 0
Originally Posted by bitcore
toe.
called up my dealership again and talked to a service advisor. he said that bmw are designed to pull (a little) to the right after a few seconds from releasing your hold on the steering wheel while driving on a straight and level road. this, he said, is to ensure that vehicles drift right and not left whenever the driver falls to sleep. (i'm not so convinced)
he also said that rear tires on bmws are designed with positive camber (top leaning in) to aid in cornering. used:
Old 03-25-2006, 11:19 PM   #13 (permalink)
Photos: 0
98estorilm3 is on a distinguished road
that sounds like BS but my m3 is drifting right when i get off the steering wheel ever so slightly
98estorilm3 is offline   Reply With Quote
Old 03-26-2006, 01:27 AM   #14 (permalink)
tomctx's Avatar
Photos: 0
Most roads are "crowned". That is, they are taller in the middle than on the ends. This helps water to run off faster. Some crowns are higher than others. The fact that you will be slightly leaning to the right might have something to do with you steering to the right. I wouldn't worry if it drifts a little bit. If it moves to the right quickly, then have the alignment checked.
Old 03-26-2006, 04:16 AM   #15 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
My M3 slowly goes to the right too, and it had a full dealer alignment less than a month ago.
1995 E38 740iL. Highly modded. Faster than you.
Lindsay fan club member.
vB code is On
Proper Alignment is VERRY Important! Eric S. 5-Series (E12,E28, E34, E39, E60) 6 12-27-2005 07:43 PM
Just a little story & an Alignment? Red93B3M2W5i 3-Series (E36) 6 09-19-2005 09:47 PM
Alignment Issues Wurzig-Drei 3-Series (E36) 0 05-10-2005 08:59 PM
Alignment And Light Steering ErikB 5-Series (E12,E28, E34, E39, E60) 4 02-01-2005 04:53 PM
Weighted Whell Alignment on 325 CIC sport Mike55 3-Series (E46, E90) 0 06-02-2004 03:04 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
