Alignment/ coil-over question - BMW Forum - BimmerWerkz.com
Old 04-25-2006, 06:36 PM   #1 (permalink)
topless_328's Avatar
topless_328 is on a distinguished road
So my rear alignment isn't exaclty perfect. I ride down the steet staight as an arrow, but my tire wear is brutal. My inside tread is now completely slick.
When i eye-ball it....the rear alignment looks a little pigion toed, but my mechanic told me there's nothing he can do without a chassis pull. And this is because, yes, it was rear ended once (i wasn't the owner).
So my question is, i really want to put a coil-over suspension on this summer. Will a fully adjustable kit, and rear camber kit fix the problem. And if so, is there any other parts i need for a suspension upgrade (rear adjustable control arms, shock mounts? etc???)
Thanks for help!
Mike
-Automotive Engineer in Training-
topless_328 is offline   Reply With Quote
Old 04-26-2006, 09:01 AM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
so basically your saying, your frame is bent, and thats whats causing the rear wheels to be off?
-SOLD..
R.I.P Fast 6
Old 04-26-2006, 10:21 AM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
From what you have said.. it sounds like your old suspension is completely shot... to the point that your rear tyres have excessive camber.
If you put a coilover suspension on your car... I highly suggest getting a rear lower control arm kit too... which can control camber relatively good in the rear tires... and provide a few other adjustables...
Les
1997 E36 M3 1990 E30 325i
Old 04-26-2006, 12:52 PM   #4 (permalink)
Its defintly not totally shot. The ride is fine, its i'd just like to see a little more life out of my tires b/c at this rate, i'll go threw a new set of tires every 2 summers.
I also think the fact that i pile lots of ppl in my car on a weekly basis might have somthing to do with it. But thats soon coming to an end. Those bums are getting there own cars now.
So les, you think a rear lower control arm kit will help. Any suggestions for the brand??
Mike
Old 04-26-2006, 04:21 PM   #5 (permalink)
tomctx's Avatar
Sounds like toe-in, toe-out is your problem. If they look pigeon-toed, that is. Camber is the way the tire leans from vertical. I don't see why you can't change the toe on the car. I would get a second opinion from another mechanic. Try to find one versed in the rear suspension. There are a lot of things that can be moved around on your rear suspension as it is.
Old 04-26-2006, 04:55 PM   #6 (permalink)
Thanks, thats definitly my next move i think.
Mike
Alignment 101 441tech 3-Series (E46, E90) 4 12-10-2009 10:46 AM
Proper Alignment is VERRY Important! Eric S. 5-Series (E12,E28, E34, E39, E60) 6 12-27-2005 06:43 PM
Bilstein Coil Over Question skyrider 3-Series (E46, E90) 1 04-12-2005 08:27 PM
Tire / alignment question Skipjacks M-Series (M1, M3, M5, M6) 9 08-02-2004 06:49 PM
90 525i - bad ignition coil? thebaldguy 5-Series (E12,E28, E34, E39, E60) 1 04-26-2004 03:38 PM
