Alarm Problems - BMW Forum - BimmerWerkz.com
Old 12-11-2004, 04:37 PM   #1 (permalink)
untouch@ble is an unknown quantity at this point
Hi
I have a BMW 3.18i (N 1996) UK model.
Recently the central locking on the back left door failed to work, the only way I can lock the door from the back now is doing it manually. Also I can no longer arm my alarm on the car using the remote key - is this a simple fuse change or deeper problem such as wiring.
As for the alarm problem I have made sure all doors are shut properly - done this around 5 times.
I am new to this site and BMWs for that matter and would appreciate any guidance.
Thanks in advance.
Steven Anderson
untouch@ble is offline   Reply With Quote
Old 12-11-2004, 05:55 PM   #2 (permalink)
Fadec40 is an unknown quantity at this point
Is the problem happening using the remote?
It may need a new battery. That is the easiest first step in troubleshooting it!
Fadec40 is offline   Reply With Quote
Old 12-11-2004, 06:15 PM   #3 (permalink)
BUSTaMOVE is an unknown quantity at this point
check the fuse,
BUSTaMOVE is offline   Reply With Quote
Old 12-11-2004, 07:14 PM   #4 (permalink)
mostwired is an unknown quantity at this point
I had that problem, also on a rear left door, and on a '96 318i - what a coincidence It may be a door lock actuator being stuck.
As for the alarm, can you hear the honks when you click Lock or Unlock? If not even red light on the remote comes up - must be the battery. If the battery is okay - maybe, the alarm unit lost the remote's code - and the remote needs to be programmed again.
mostwired is offline   Reply With Quote
Old 12-12-2004, 08:58 AM   #5 (permalink)
Hi
When I press use the remote the alarm arms itself - i.e. the doors lock but then the alarm goes into alert
The red light comes up in the car - to show the alarm is working.
Regards
Old 12-12-2004, 11:09 AM   #6 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
How do you reprogram the alarm?
Storamin is offline   Reply With Quote
Old 12-12-2004, 06:41 PM   #7 (permalink)
To teach your alarm system the unique identification code of a replacement alarm remote:
NOTE: Steps 1 through 6 must be performed within 45 seconds.
1) Close all doors, trunk and hood.
2) The alarm must be in 'disarmed' mode and key must be removed from the iginition,
3) Open the trunk and leave it open.
4) Open the driver's door and sit in the seat.
5) Close the driver's door.
6) Cycle the iginition switch 5 times between the OFF position and position #2 (ignition ON position - all dash warning lamps illuminate). The cycling must be done within 10 seconds and do NOT start the car. The red LED will illuminate continuosly and the siren will chirp once indicating the code learning mode has been initiated.
7) Open the driver's door but remain seated.
8) Close the driver's door.
9) Press and release any button on the remote you want to register into the system. The status LED will shut off momentarily to indicate that one ID code has been registered.
10) Repeat steps 7 through 9 to register any additional transmitter codes you wish the system to learn.
11) Open the driver's door and exit the vehicle LEAVING THE DOOR OPEN.
12) Close the trunk.
13) Close the driver's door. The LED will turn off and the siren will chirp twice.
14) Test transmitter to confirm operation.
It is possible for the system to memorize a total of 4 different ID codes. As a new code is learned the oldest code in memory is deleted. To wipe the system of all previous codes simply teach it the code from your current transmitter 4 times.
E36 328 Factory Alarm Problems Dayvg 3-Series (E36) 13 06-16-2005 07:24 AM
Bmw Alarm Vs. Viper Alarm dugies25 Audio and Electronics 8 03-24-2005 03:48 PM
Stereo And Alarm Problems Junior1683 Audio and Electronics 6 10-10-2004 05:25 PM
Factory Fitted Alarm smoker 3-Series (E36) 5 03-08-2004 11:40 AM
