Alarm Help - BMW Forum - BimmerWerkz.com
Old 01-10-2005, 02:18 PM   #1 (permalink)
Black318IS is an unknown quantity at this point
I remember a while ago that someone had a code on here for turning on the security system and i did the search but nothing came up. I know that it had to do with opening the trunk, walking into the car, then something, then getting out and closing and locking the door and then closing the trunk. Can anyone help me out?
Black318IS is offline   Reply With Quote
Old 01-10-2005, 09:03 PM   #2 (permalink)
Rooz's Avatar
Car: 2003 M5
I'd like to know that answer to this one too? Anyone???
And yes, it is something similar to that. First, you close all the doors (not lock), then you open your trunk. GO in the car, crank (but not start) then close trunk, then I THINK! Crank it (but not start) 8 times in a row, I could be wrong on my numbers. And if you do it right, the little red led in front of your gears will falsh saying it's ready for the remote. Now, if you do this right, and the led doesn't flash, then you have the same problem as I do, whish I have no idea on how to fix.
VIEW MOD LIST & PICS
Originally Posted by Gregg
Rooz is offline   Reply With Quote
Old 01-10-2005, 09:49 PM   #3 (permalink)
emust is an unknown quantity at this point
Try this link. It worked for me.
http://www.mz3.net/articles/259.html
emust is offline   Reply With Quote
Old 01-27-2005, 07:18 PM   #4 (permalink)
TeeUp's Avatar
Car: 2002 X5 3.0i and 2007 X5 3.0i
TeeUp is an unknown quantity at this point
[snapback]268618[/snapback]
i don't know what i missed but i seem can't get it right......
here's the full text:
Each remote transmitter has a unique identification (ID) code. In order for a replacement remote to operate your security system, or to delete the ID code from a lost remote, you must follow the procedures detailed below so that your system's control module will learn/delete the desired ID code(s). This code-learning initialization procedure must be followed precisely within the sequence and time constraints specified, in order for the procedure to be carried out successfully.
Preparation
1. Close all doors, trunk, and hood.
2. The security system must be in "disarm" mode. The key must be removed from the ignition key slot.
Enter Code-Learning Mode
3. Open the trunk and leave it open.
4. Open the driver's door and sit in the driver's seat.
5. Close the driver's door.
6. Cycle the ignition switch five times between the "off" position and position 2 (ignition "ON", all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will "chirp" once, to indicate that the code-learning mode has been initiated.
<span style='color:gray'>NOTE: i cant get to have the LED illuminate. should the key be left on the "on" position or back to "off"? should the key be removed??? help!!!!
DO NOT START THE ENGINE
The ignition switch cycling in step #6 must be performed within ten seconds.
The sequence in steps #1-6 must be performed within 45 seconds.
Registering/Delete ID Code(s)
7. Open driver's door, (remain seated in driver's seat)
8. Close driver's door.
9. Press and release any button on the remote you wish to register into the system. The status LED will shut off momentarily to indicate that one ID code has been registered.
10. Repeat steps 7 through 9 to register the remaining three ID codes.
Exiting Code-Learning Mode
11. Open driver's door, and exit from vehicle, leaving the door opened.
12. Close trunk.
13. Close driver's door. The LED will turn off and the siren will "chirp" twice.
14. The initialization procedure is now completed, test all remotes to confirm operation.
It is possible for the system to memorize a total of four different ID codes. As a new code is initialized into memory, the oldest code in memory is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from memory, you could initialize the ID code from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from system memory.</span>
TeeUp is offline   Reply With Quote
Old 01-27-2005, 08:03 PM   #5 (permalink)
Rooz's Avatar
Car: 2003 M5
You have the same problem as I do, you need a new alarm module probably...
Old 01-27-2005, 09:33 PM   #6 (permalink)
frank3 is an unknown quantity at this point
Those instructions won't work if you have a '95 or before alarm...the three-button remote. If you have this alarm, you need to access the alarm "brain" behind the glove box, place the chip that's in your remote into the brain and push a button.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 01-27-2005, 09:47 PM   #7 (permalink)
TeeUp's Avatar
[snapback]280691[/snapback]
do i? but my alarm system is doing perfectly fine. i just wanted to add an extra remote just in case i lose mine.
Old 01-27-2005, 09:49 PM   #8 (permalink)
TeeUp's Avatar
[snapback]280747[/snapback]
you must have meant if i had the alpine alarm, which i dont. what i have is the two button with part no. 82 111 469 448.
Bmw Alarm Vs. Viper Alarm dugies25 Audio and Electronics 8 03-24-2005 03:48 PM
Alarm questions wulley1 3-Series (E36) 4 05-24-2004 10:31 PM
Factory Fitted Alarm smoker 3-Series (E36) 5 03-08-2004 11:40 AM
Funny thing about factory alarm mostwired 3-Series (E36) 9 01-26-2004 02:16 PM
