Air Intake Temperature Sensor.... - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 03-21-2006, 04:10 AM Thread Starter
bmw325ise is on a distinguished road
Hi Guys, wonder if you can help. About 3 weeks ago I had an issue with my car whereby when you start it the revs would go to about 2k then drop to below 300rpm and fluctuate until a steady idle is achieved. I took the car to a BMW Stealership and they ran a diagnostic check on the car.
It came back saying that the Air intake temperature was faulty. BMW traced the problem from the ECU back the to the sensor and found corrosion, they cleaned the connection up and all was ok… Until now, it’s playing up again. I wanted to check the sensor myself but I have no idea where to look for it, some article around the net have suggested it’s built into the MAF.
The car is a 94 318is with the M42 engine…
Any Help would be very much appreciated.
Thanks..
Andy
bmw325ise is offline
post #2 of 5 (permalink) Old 03-21-2006, 04:29 AM
LYFE SUCK5
Ivan's Avatar
Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future Ivan has a brilliant future
Send a message via AIM to Ivan
i have the same problem.
Ivan is offline
post #3 of 5 (permalink) Old 03-21-2006, 04:43 AM
vwk
vwk is an unknown quantity at this point
It's inside the MAF, when you open the valve inside the MAF you should shee a small plastic-like pin, on the upper side in the middle.
27 years
vwk is offline
post #4 of 5 (permalink) Old 03-21-2006, 05:15 AM Thread Starter
Thanks for the quick response, can i change the sensor or will it need a whole new MAF? Am gonna clean the ICV this weekend, when the car is at idle it feels a little rough although the revs seem fine. Any Ideas?
post #5 of 5 (permalink) Old 03-21-2006, 05:27 AM
vwk
Use WD40 or some brake cleaner. There is not so much to clean of the sensor, maybe some WD40 or brake cleaner also would help there.
Otherwise there is no other option then changing the MAF.
27 years
vwk is offline
Check Engine Light came on today camnipotent 3-Series (E36) 24 08-08-2014 05:20 AM
dinan cold air intake differences cmodem 3-Series (E36) 6 03-09-2006 12:15 AM
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Ambient Temperature Sensor Tacorom6969 3-Series (E36) 7 07-17-2005 01:42 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
