| Ive got a 1992 318I The Bentley books says to check the the air flow meter you put an ohm meter between terminals 1 and 2 and move the flap. I have 2 meters and both of them check the same no matter how much you move the flap. Is the book wrong or do i have 2 bad meters. The problem im tring to fix is a small miss around 2000 RPM in 2nd and 3rd gear. |
