Air Con Faulty - BMW Forum - BimmerWerkz.com
Old 07-23-2008, 07:06 AM   #1 (permalink)
geeman028 is on a distinguished road
Air Con Faulty
Hi, I have just bought a BMW 318Si 1998 Coupe and the AC works only sometimes. It will sometimes atart then blow for maybe 3-5 mins then cut out and will not come back on for a while then sometimes just starts blowing again. Has anybody else had same problem and if so what was wrong please. Thanks in advance
geeman028 is offline   Reply With Quote
Old 07-23-2008, 09:24 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
are you sure the cabin blower is not at fault?
If you suspect you Air conditioning unit, possible cause/s:
1) lack of freon in system,
2) faulty receiver/drier,
3) moisture/air in your A/C system.
*dunno what your level of DIY savvy is, but if you are doing this on your own, someone here will gladly walk you through CORRECT diagnostics.
Cheers
Old 07-25-2008, 06:55 PM   #3 (permalink)
krause107's Avatar
krause107 is on a distinguished road
I think you have a common problem...my control would go dim or off and then would come back on again. There's a problem with a little transistor in the system. You can send it to some guys in Idaho (I think) on ebay. I got mine fixed in a week for $45.
krause107 is offline   Reply With Quote
328ci Air Con Probs sweetdude 3-Series (E46, E90) 4 08-10-2005 08:16 PM
Air Con danieladams 3-Series (E46, E90) 1 06-05-2005 11:58 AM
E39 5281 Air Con chiddy 5-Series (E12,E28, E34, E39, E60) 2 04-21-2005 05:18 AM
Smelly air con ! Poot_1873 3-Series (E46, E90) 16 10-02-2004 05:33 PM
Air con filter case_sense 3-Series (E36) 4 11-28-2003 03:49 AM
