aftermarket stereo problem - BMW Forum - BimmerWerkz.com
Old 12-12-2005, 02:12 PM   #1 (permalink)
92_325i is an unknown quantity at this point
hey guys....i'm having/ have been having a problem with my stereo in my 92 325i. in very early july i was driving along and the stereo was starting to cut out, like two wires were touching that shouldnt have been. the next day, i get in the car and the radio isnt working. it was an aftermarket cd player that was working perfectly fine earlier the day before. everything was functioning as it should, except i'm not getting any sound at all, not even static. digging around the car a while ago, i found that the amp in the trunk had a blown fuse, so i replaced it. that solved nothing. now today, i just pulled another stereo out of my other car that i know works, and installed it in the E36 and i'm still having the same problem. any one have any ideas as to why i'm getting no sound?? any help would be great.
<a href='http://www.cardomain.com/id/jordan92bmw325i' target='_blank'>My 1992 325I</a>
<a href='http://www.cardomain.com/memberpage/461648' target='_blank'>My 1989 Nissan 240sx</a>
<a href='http://www.cardomain.com/member_pages/view_page.pl?page_id=724529&cat=10&val=1&page=1' target='_blank'>My girls' 1998 Camaro</a>
92_325i is offline   Reply With Quote
Old 12-12-2005, 02:34 PM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
does it power on?
-SOLD..
R.I.P Fast 6
Old 12-12-2005, 02:36 PM   #3 (permalink)
Power Shifting
also... if i were u.. i would check all the wires that u had to splice together... and solder them back again..
-SOLD..
R.I.P Fast 6
Old 12-12-2005, 02:36 PM   #4 (permalink)
yeah. it powers on and all functions are normal. it'll take cd's in and eject them when i want it to, i'm just getting no sound at all.
checked the wiring 5 or 6 times.....
Old 12-12-2005, 02:39 PM   #5 (permalink)
Power Shifting
its def a wireing problem...
-SOLD..
R.I.P Fast 6
Old 12-12-2005, 02:41 PM   #6 (permalink)
i dont think it is a wiring problem. i have checked the wiring many times and have found no problem with it anywhere. i've installed dozens of stereo's before and never had a problem. and if it was wiring, it wouldnt have just happened all of a sudden like it did.
Old 12-12-2005, 02:42 PM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Have you checked to see if your getting any sound from the unit... players might work fine... but the might not send music out... I've had that happen twice....
And this should be in the audio forum... ahh... I see there is a double post... so now your a double poster....
Goodness
Les
1997 E36 M3 1990 E30 325i
Old 12-12-2005, 08:59 PM   #8 (permalink)
318itx is on a distinguished road
are your stereos hooked up through the CD player? or through an amplifier? if its through the stereo then i'd say its a definite connection problem; but if you've replaced the stereo and still the same problem, im going to assume that your speakers are hooked up through an amplifier. if this is so, go out and buy a wire tester, its a little screw driver looking thing that has a tip on the and a light in the middle, im sure you know what im talking about. anyways, use that to try and test your connections, first connect it to your power to see if your getting sufficient amount to the amplifier, next hook that ground section up to it and test the power again to make sure your getting a sufficient ground connection, after that i'd test each and every one of your speakers, and if you can't find a solution i'd say replace the amplifier. if you blew a fuse, then there was a short with a connection somewhere, with amps if the short is still going on the amp will turn on but will usualy have a red light instead of a green one, or something of that sort.
318itx is offline   Reply With Quote
Old 12-12-2005, 09:48 PM   #9 (permalink)
the fuse i blew was in the stock amp or whatever in the trunk. i am assuming that is the problem. if it was a problem with wiring, either it would work or it wouldnt work. does anyone know if i could bypass the OEM amp in the trunk without a major re-wire deal? it's cold out and i dont feel like being out there for long if i dont have to.
Old 12-12-2005, 10:28 PM   #10 (permalink)
my suggestion is say fuck the oem amp you have, and go get yourself a real one
wire that amp up(not to hard probably just steal the wires from the stock amp) and you'll be ready to go.
aftermarket stereo problem..E36 92_325i Audio and Electronics 1 12-13-2005 09:04 PM
Aftermarket Stereo schneidmj Audio and Electronics 11 04-24-2005 02:26 PM
Stereo Problem Solved! jeppcharts 5-Series (E12,E28, E34, E39, E60) 6 09-26-2004 01:08 PM
Stereo Problem Solved! jeppcharts Audio and Electronics 0 09-04-2004 09:58 PM
Electrical Problem AC Stereo byttcool 5-Series (E12,E28, E34, E39, E60) 5 07-26-2004 09:13 AM
