Aftermarket Headlights - BMW Forum - BimmerWerkz.com
Old 05-06-2005, 03:43 PM   #1 (permalink)
zlac109 is an unknown quantity at this point
Hey guys
I just got some aftermarket headlights for my e36. The ones with the angel eye rings. Trying to put them in however there's a bit of a problem. I took out one of the old headlights earlier today but the new ones seem to be completely different, i mean the wiring and everything. What is the deal, do i need extra parts or what
Thanks
zlac109 is offline   Reply With Quote
Old 05-06-2005, 04:33 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
What kind did you get.... from where... what company?
Les
1997 E36 M3 1990 E30 325i
Old 05-06-2005, 05:17 PM   #3 (permalink)
Les
[snapback]341589[/snapback]
I do not know which company they're from i got them from ebay but i can give you the picture
http://i12.ebayimg.com/01/i/03/d2/52/c0_1_b.JPG
Old 05-06-2005, 08:12 PM   #4 (permalink)
dopeyx27's Avatar
dopeyx27 is an unknown quantity at this point
Send a message via AIM to dopeyx27
whoa, ebay headlights.. they should be the same wiring. you got some flix of the wiring on those?
dopeyx27 is offline   Reply With Quote
Old 05-06-2005, 08:13 PM   #5 (permalink)
dopeyx27's Avatar
if your talking about hooking up the angel eyes, you could tap the GREY wire to your corners.
Old 05-06-2005, 08:50 PM   #6 (permalink)
jvsantosmd is an unknown quantity at this point
Hello:
Ussually you have to cut your connectors and rewire them into the new headlights. The gray cable goes to the sidemarkers so the little light inside the high beam headlamp light up when you turn your low beams on. Not as complicated as it seems, can be done in about one hour. Just take your time and PLEASE use good quality connectors.
Now for the VERY BAD NEWS: I've found out that although they may look very cool and may look very avant-guarde, you will not be able to see anywhere near what the stock headlamps gave you... they just don't focus the light beam in front of the car. And if you try to go Xenon ( with ballasts... $$) your light beam will REALLY suffer! So take your time and think... do you want lo look good or do you want to SEE good?
Jose
jvsantosmd is offline   Reply With Quote
Old 05-06-2005, 10:06 PM   #7 (permalink)
it's hard to believe the light from a projector beam could be any worse than the stock units. Has anyone else had this problem with ebay lights?
Installing Aftermarket Amp/sub In E34 Dr. Pipper Audio and Electronics 4 03-03-2009 07:43 AM
Aftermarket Headlights zlac109 3-Series (E36) 3 05-07-2005 11:38 AM
New E46 HID headlights jnleo20 3-Series (E46, E90) 8 07-25-2004 01:06 PM
FS: Early E39 Headlights with pix ni5moserspecv Classifieds Sell & Buy 2 01-13-2004 09:29 PM
