accelerator pedal - BMW Forum - BimmerWerkz.com
Old 01-06-2006, 09:32 AM   #1 (permalink)
SILVER 325 is on a distinguished road
Angry accelerator pedal
right got a problem when driving and stepping off the accelerator to change gear the car stays at 3 thousand revs because the pedal isnt lifting up fully ive tried spraying WD40 on it and no change does anyone know a cure for this cheers
SILVER 325 is offline   Reply With Quote
Old 01-06-2006, 11:32 AM   #2 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
check the throttle body under the hood, or the cable, you cna start the car and lift the hood and pull the throttle back from under the hood, see if it is getting stuck under there. could be that the cable is getting bad or frayed or whatever. but check under the hood. cheers
kyle_baker is offline   Reply With Quote
Old 01-06-2006, 11:52 AM   #3 (permalink)
it isnt that i checked that its the plastic pedal in the interior its kind of weird
but thanks anyway
Old 01-06-2006, 02:03 PM   #4 (permalink)
kyle_baker's Avatar
but thanks anyway
you could replace the little hinge peice on it, maybe it is just messing up due to wear. i'm not sure what part number this would be or anything, it may be the entire pedal that you have to replace. but if its not in the throttle body and you're sure, then just replace the hinge peice or the pedal. you could take one from a junked e36 or something pretty cheap.
cheers, hope you get it sorted out!
Old 01-06-2006, 03:15 PM   #5 (permalink)
BMW Kraft's Avatar
BMW Kraft is on a distinguished road
check your floormats, i had the same problem, my floormat got unhooked and shifted forward and sat on top of the gas pedal
'92 318i - Bilstein Sport Tuned Suspension, Performance Tuned Chip
///BMW=-
BMW Kraft is offline   Reply With Quote
