| AC\Heat not blowing Hi,
This has happened 3 times in the past couple months. I start my car up and turn the AC on and I can hear the AC compressor come on but no air comes out of the vents. I mess with all the settings and turn it off and on, no heat comes out when i switch it to heat and no air comes out when i switch the AC off. Sometimes I think I feel a little air (about 2 seconds worth) when I switch the AC off but leave the fan setting on full. The first time this happened I turned the car off and started it again and it worked fine. The last couple times I had to restart the car 5 or 6 times. Usually the AC work fine, but this happens every now and then and Ide like to get it figured out. Once again, the AC compressor definitely is comming on cause I can hear it and feel it in the idol, but no air comes out of the vents at all. Has anyone seen this before?
Thanks a lot
- Justin - |
