Abs Warning Light - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 12-03-2004, 07:47 AM Thread Starter
jamesw is an unknown quantity at this point
Hi guys,
Any chance you would have had the exprience that the ABS warning light keeps on, but with no ill to the brakes?
Could that be an indication of battery running flat soon? or other seasons?
Regards,
James
jamesw is offline
post #2 of 6 (permalink) Old 12-03-2004, 08:28 AM
Fadec40 is an unknown quantity at this point
When your ABS system has a malfunction, it doesn't affect NORMAL braking. There are many things that cause the ABS light to come on.
Believe me, when your battery is going dead, you'll know!
Fadec40 is offline
post #3 of 6 (permalink) Old 12-03-2004, 11:27 AM
DesmoBob's Avatar
Originally posted by jamesw@Dec 3 2004, 02:47 AM
Hi guys,
Regards,
James
[snapback]242579[/snapback]
a few things you can check yourself:
- fuses
- relays
- wheel speed sensors & their respective connectors
if all those check out ok, you have to get the codes read because you have a much deeper problem.
on a related note:
http://www.bmw-forums.com/forum/inde...howtopic=25426
DesmoBob is offline
post #4 of 6 (permalink) Old 12-03-2004, 05:13 PM Thread Starter
Thanks Fadec40 and DesmoBob.
I think the fuse and relay are ok, the light can be reset at each starting, but it comes back on after braking or sometime later. The reason I suspect the performance of battery is that in one instant, the electric gear control warning light was also lighted up (but surprisingly never seen the battery light).
Bob, can you tell me how to check the "wheel speed sensors & their respective connectors" please.
Regards,
James
jamesw is offline
post #5 of 6 (permalink) Old 12-03-2004, 07:04 PM
DesmoBob's Avatar
wheel speed sensors & connectors:
(same procedure for each wheel)
connector: remove wheel, you will see a wire coming through the wheel well down to the area behind the brake rotor. that wire goes through a coupling (connector) attached to the wheel well. check that the connector has not come loose or frayed.
sensor: unbolt the sensor (follow the wire) from the rear of the hub. the sensor is magnetic and over time it gets gunked up with dust & debris. shoot some compressed air or brakleen on it.
also (offhand i don't remember this procedure exactly), behind the disc rotor there is what resembles a toothed disc, something like a sprocket, that is where the speed sensor picks up its signal. make sure that hasn't gotten filed down by random debris getting caught between the "sprocket" and the sensor. if you need more detail than this, reply to this post, i'm writing this at work from memory, have to consult manuals at home.
DesmoBob is offline
post #6 of 6 (permalink) Old 02-06-2005, 08:33 PM
sebastian is an unknown quantity at this point
[snapback]243006[/snapback]
Hi, First of all i'd like to appologize about my english, but is not my native lenguage. I hope you understandme anyway.
I have the same problem. My ABS ligth comes on in the middle of the trip with no apparent reason. I take my car to a BMW dealer and get connected to de Diagnose computer, and it found no fault. I`ve tested the ABS while the ligth is on and it's not working
All that i've read makes me think that the problem may be in the wheel speed sensor. I found your expalnation gorgeous. Woud you please explain in more detail how can i test and eventually fix (if possible) the speed sensor? and how can i disconect the grey connectors (i try but i cant)?
Thanks in advance. Best regards for everyone
sebastian is offline
"help! I Want Better Headlights On My 3er!" jlevi 3-Series (E46, E90) 55 11-19-2012 02:23 PM
318ise Engine Warning Light DB666 3-Series (E46, E90) 0 12-31-2004 09:48 AM
Pad Brake warning light - problem Infinity 3-Series (E46, E90) 5 07-07-2004 01:50 PM
Brake Lining warning Light Jefbrunton 5-Series (E12,E28, E34, E39, E60) 5 01-07-2004 05:07 PM
Brake Lining warning Light Jefbrunton 5-Series (E12,E28, E34, E39, E60) 1 11-29-2003 08:25 AM
