Abs and Traction Control Lights - BMW Forum - BimmerWerkz.com
Old 08-18-2004, 12:20 PM   #1 (permalink)
Cannon00000 is an unknown quantity at this point
The ABS and traction control lights are continusouly on, on my 95 325is. Being new to BMWs I wasnt sure what exactly these are telling me, and was hoping for some advice before taking it to a mechanic. Also there is a contionous squeaking in the front left wheel well. I was told might be a stablizer pin, whatever that is. Anyone know what I should do or what is wrong? KC
Cannon00000 is offline   Reply With Quote
Old 08-18-2004, 01:20 PM   #2 (permalink)
Threadkiller
bitcore's Avatar
As for the ASC, there is a malfunction with it and you need to have it checked out. It could be a number of things.
Old 08-18-2004, 01:35 PM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
if u don't want to spend God knows how much on it, then just take the bulb out!!! hahaha... BUT IF ITS GIVING U PROBS... then get it checked out!!
-SOLD..
R.I.P Fast 6
Old 08-18-2004, 02:38 PM   #4 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
my ABS light was constant on for awhile but when I changed out my old break pads and got new ones the ABS light went out, maybe what your having going on??? just a thought
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 08-18-2004, 02:40 PM   #5 (permalink)
Car: 2008 128i
the ASC light is most likely in conjuction witht he ABS light because its not properly able to monitor wheel spin to kick the ASC in so it maybe a ABS sensor problem.
2008 128i Jetblack
Old 08-18-2004, 06:00 PM   #6 (permalink)
RIBEMR26's Avatar
I have a button to turn my ASC on and off. When I turn it off, the light stays on...I would have it checked out to make sure it is working properly. I can't imagine driving my bimmer in bad weather (snow) without it!
Clear Corners and Sidemarkers
Old 08-18-2004, 08:51 PM   #7 (permalink)
Laker is an unknown quantity at this point
On my 94 325 the Brake Light Circuit warning was showing up on the Multi-information Display. In the owners manuel it says it could be a bulb, fuse or circuit defective. What I found out is there is a brake pad wear sensor that tripped the warning. I need new brake pads, thats all. Sensors are located on left front and right rear. I've had this car only a week so I'am no expert by any means with BMW's. But maybe this might help you out. Good Luck
Laker is offline   Reply With Quote
