ABS & Traction Control - BMW Forum - BimmerWerkz.com
Old 08-16-2003, 04:40 PM   #1 (permalink)
carabeem is an unknown quantity at this point
<span style='font-size:14pt;line-height:100%'>I have a 1995 325is and had it since it was new. Had no problems with it except now the abs and traction control idiot lights are now on all the time. Has anyone experienced this type of problem and does it have to be brought to a dealer.
Thanks
</span>
carabeem is offline   Reply With Quote
Old 08-16-2003, 04:49 PM   #2 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Could be a loose connector..I'd take it to the dealer and have them check on it..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 08-16-2003, 06:29 PM   #3 (permalink)
EXtech's Avatar
too many possibilities. Take it to the dealer and have them pull the fault codes. Then decide if you want to tackle the replacement yourself.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 08-16-2003, 06:32 PM   #4 (permalink)
could be the sensors or voltage regulator
Old 09-10-2003, 09:11 PM   #5 (permalink)
x2nervisx is an unknown quantity at this point
Did you ever find out what was wrong? I also have a 1995 325is and the abs and traction control lights are on.
x2nervisx is offline   Reply With Quote
Old 09-13-2003, 07:25 PM   #6 (permalink)
K-State Bimmer is an unknown quantity at this point
The only real possibilities for this would be either the wheel speed sensors, or the relay for your ABS. It would most likely be the wheel speed sensor. You should bring it to your local dealer, have them diagnose to figure out which sensor it is. There are sensors on every wheels brake assembly, only one should go bad at a time. Once they tell you which one is bad, walk out and call Autozone or some other local car parts store. BMW wants $90 a piece, whereas the other stores only want about $30. It is a very easy install. All you have to do is unplug your old one and then plug in the new one.
K-State Bimmer is offline   Reply With Quote
Old 09-14-2003, 11:44 AM   #7 (permalink)
EXtech's Avatar
not true, there are many possibilities there. The best thing to do is have the fault codes checked (preferably by a dealer).
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
traction control at the track milkeyisback 3-Series (E21, E30) 2 09-26-2005 12:52 AM
Traction Control Not Working Tochenzo 3-Series (E36) 5 03-21-2005 09:41 AM
Did The 1995-1999 ///m3 Come With Traction Control MadBMW M-Series (M1, M3, M5, M6) 4 02-13-2005 01:09 PM
Traction Control bigred318 3-Series (E36) 14 12-20-2004 05:47 PM
Traction Control Light nit78 3-Series (E46, E90) 2 01-28-2004 12:19 PM
