ABS problem - BMW Forum - BimmerWerkz.com
Old 05-17-2006, 04:13 AM   #1 (permalink)
hatsiekatsie is on a distinguished road
ABS problem
Hello,
I have a problem with my ABS. When i start the engine and i drive for about 3 kilomters(sometimes more or less) the yellow ABS lamp goes on. Also when i do an emergancystop the light goes on. So the ABS doesn't work at all!
The following code's where found:
code001:
82 Wheel speed sensor, front right, not installed or faulty
113 faulty wheel-speed information, front left, not detected
code002
116 wheel-speed information, rear left, not detected
code003
120 wheel-speed information, rear right, not detected
code004
132 pedal-travel-sensor signal not sent or faulty
Must i clean the sensors?
Must i replace de pedal-travel-sensor?
Silvan, Vlissingen, Holland
hatsiekatsie is offline   Reply With Quote
Old 05-17-2006, 03:52 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
first off clear all the faults and see which one comes up, than work on getting that problem fixed, chances are the other codes came up as a result as the first code.
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
E36 M3 ABS problem djhowie M-Series (M1, M3, M5, M6) 2 04-29-2006 02:47 PM
E34 trans prog problem exacerbated electronblue 5-Series (E12,E28, E34, E39, E60) 5 03-02-2006 10:07 PM
Perplexing Problem Starting my 87 528e arkhaus 5-Series (E12,E28, E34, E39, E60) 5 02-04-2006 08:17 AM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
