ABS Light troubles! - BMW Forum - BimmerWerkz.com
Old 07-23-2003, 04:12 PM   #1 (permalink)
javiwwweb is an unknown quantity at this point
Thumbs up
Hello everyone, I just found this great forum and it has been a fountain of information. The only problem is that I'm not sure my question has been covered before since the search button doesn't seem to work for me. Anyway, here goes. A little while ago I was replacing my rear-wheel bearings and for some reason I had to take out the ABS sensor. After the job was completed, I put everything back in place and from that point on my ABS light has been on. I tried taking out the sensor cleaning it and then putting it back in... no luck... Then I tried the oposite putting some grease on the sensor (since it had some to begin with, and again, no luck. What can I do now? It's obvious that I did something to it when I pulled it out, but will replacing it solve the problem? Why would this happen?
Javiwwweb ghead
javiwwweb is offline   Reply With Quote
Old 07-23-2003, 06:59 PM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
My guess is that pulling the sensor flipped a bit in the On Board Computer. Translation - you probably need to take it a dealer and have them reset the light for ya, or get a tool that does the resetting.
Good luck, cheers, welcome to the forum, and next time wipe you feet huh. You tracked mud all up in this bizznotch and I gotta bust out the mop now ... *grumble grumble*
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 07-23-2003, 07:15 PM   #3 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Hey welcome javiwwweb!! B)
Like GD stated you'll prolly going to have to have your OBC reset because the ABS sensor set off a fault code in there when you took it off..there is a way to do it yourself but I recommend you take it to the dealer on this one!!
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 07-23-2003, 10:28 PM   #4 (permalink)
Thanks guys. I'll definitely take it to the dealer. I was kind of hoping that it would be something simple. I guess i'll cross my fingers. Thanks Again.
Javiwwweb
Old 07-31-2003, 09:59 PM   #5 (permalink)
ex owner/admin
Furious's Avatar
try getting the fault cleared , mechanics will use the modec tool. anyways , if that fails at least youll know whats wrong , with ABS it could be a few different things, left or right, speed sensor, brake sensor, etc etc
Abs/asc Light On 2000 523/525 Avatar1 5-Series (E12,E28, E34, E39, E60) 2 10-16-2004 08:49 AM
OT: Group Buy - PIAA Light Bulbs alohalc 5-Series (E12,E28, E34, E39, E60) 0 07-21-2004 05:59 PM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 10:30 PM
