| Also, do you know how to check if your ABS is working? I've just gone to dirt road/loose gravel area and then jammed brakes on at 20-30mph, and if you get the pulsating upon loss of traction, then your ABS works. :P
__________________ 98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars. |
