ABS Light On - BMW Forum - BimmerWerkz.com
Old 06-29-2004, 09:14 AM   #1 (permalink)
G-Man is an unknown quantity at this point
My '92 318i has been parked for roughly six months now, with only occasional drives (about once a month). Last week I went to move it and I noticed that the when I turned on the ignition, the ABS light did not go out. Usually when you first turn the key to the on position, virtually all the dash lights come on as the car performs the self tests. The ABS light does not go out.
My initial thought was that the relay might be bad. I popped the fuse box open and saw that there were two relays labeled ABS, one red and one gray. I took them out and tapped them a number of times but it still would not work. I then took the plastic covers off the relays but I could not detect any burnt contacts and everything appeared to be moving. I did not get out the voltmeter to bench check, I guess I will have to get around to that.
Later, I did a web search for information. Relays were a common culprit, as were the wheel sensors themselves. Does anyone know if the ABS light staying on from the get go (as opposed to coming on while driving) could be caused by dirty/faulty wheel sensors?
I also saw some discussion on ABS fault codes. Is there any way to get these codes for the common man or do I have to go to a dealer/s
G-Man is offline   Reply With Quote
Old 06-29-2004, 09:35 AM   #2 (permalink)
Fadec40 is an unknown quantity at this point
That ABS light covers a slew of goodies. Good be the relay, wheel sensors, module, etc. I suggest you have someone with know how take a look at it.
But the ABS having a fault does not affect REGULAR braking. The only immediate problem is having to look at that light while driving until you get it taken care of.
Fadec40 is offline   Reply With Quote
Abs/asc Light On 2000 523/525 Avatar1 5-Series (E12,E28, E34, E39, E60) 2 10-16-2004 08:49 AM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 10:30 PM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
