Abs - BMW Forum - BimmerWerkz.com
Old 02-05-2006, 12:31 AM   #1 (permalink)
Breaker2944's Avatar
Breaker2944 is on a distinguished road
Abs
Here's one, I start the 323is 98 and the abs light goes on, but when i step on the brake, my radio cuts off.... what do you guys think?
I'll try and change the front rotors and pads.
http://www.Teamforeignobjects.com/
Breaker2944 is offline   Reply With Quote
Old 02-05-2006, 02:09 AM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
sounds more of an electrical problem other then rotors and pads...
-SOLD..
R.I.P Fast 6
Old 02-05-2006, 08:14 AM   #3 (permalink)
/Banned
Dirty Martini is on a distinguished road
Aftermarket radio or stock? Recommend you save the money on rotors and pads and get your fault codes read. I can't imagine what ABS and the sound system have in common, but identifying and solving the ABS issue would be a good place to start.
Dirty Martini is offline   Reply With Quote
Old 02-05-2006, 09:23 AM   #4 (permalink)
mdc
mdc is on a distinguished road
electrical problem right there bud
mdc is offline   Reply With Quote
Old 02-06-2006, 02:00 PM   #5 (permalink)
e36surge's Avatar
Lets try tackling this problem through elimination.
My ABS light came on recently as well and I found this link:
http://member.rivernet.com.au/btaylo...20TSB%20Recall
I replaced the relay and the light went away and my ABS is working fine.
As for the radio, my now sold 1994 e36 318is had the same problem. My cousin is a car audio tech and he simply pulled the radio and checked the connections. Turned out to be a bad ground (bad connection).
Just my two cents.
surge
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 02-06-2006, 02:13 PM   #6 (permalink)
e36surge's Avatar
See attached picture. I replaced #11.
Old 02-06-2006, 10:09 PM   #7 (permalink)
alternator
Well here it is.... I started my car after all that crap and my battery was dead.. so i jumped it and drove around the block,, and the car went dead: got the battery checked that was good,, so i assume its the alternator, got a new one today, I'll put that in... Yea my cluster was going crazy too... ABS, ACS ect.... I'll let you know... maybe since there was a fault the system shut done things that wernt really being used at the time... I'll let you know how it comes...
Thanks for all your feedback....
Old 02-07-2006, 10:24 PM   #8 (permalink)
Alternator,, problem solved...lol
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
ABS and ACS Dashboard Warning Light barnesy1977 3-Series (E46, E90) 12 02-04-2006 08:47 AM
Need help disconnecting abs unclespok 3-Series (E21, E30) 5 01-22-2006 02:53 PM
ABS and ACS lights on intermittently warchild M-Series (M1, M3, M5, M6) 2 01-03-2006 10:58 PM
ABS System failure!!Advise needed please. BMWstealth 3-Series (E46, E90) 9 10-12-2005 08:20 PM
