98 328i Starting Problem - BMW Forum - BimmerWerkz.com
Old 10-29-2004, 09:44 PM   #1 (permalink)
moe19x is an unknown quantity at this point
Ive got a 1998 bmw 32i, i have problems starting the car in the morning when the weather is cold but once the car has started i dont have any problems all day. ive hered it could be cuz the fule injectors might be dirthy and additives are needed to clean them. do these care have the engine heating blocks??? and where would the cord for it be so i can plug it in? thankz im new to this and this is the 1st bmw i have owned. by the way this car was in storage for the past four year and has only been used daily starting october.
1998 328I
4 Door Sedan
100% Stock
moe19x is offline   Reply With Quote
Old 10-30-2004, 11:48 AM   #2 (permalink)
a couple things i forgot to mention are, prior to this car being put in storage it was only driven 5000 miles it was bought new and 6 months later it was put in storage.
i havent done a tune up on it yet, but is it necessary since the milage is under 10,000?? the only thing that was done after it was taken out of storage this year was just a oil change and coolant flush.
any advice guys?
should i change the fuel filter?, wires? air filter? spark plugs? or is there any thing else dat needs to be changed as well?
the fuel injectors might be dirty what could i do about dat?
im a total newbie and this is the first car ive owned. hers a pic of my baby
1998 328I
4 Door Sedan
100% Stock
Old 10-30-2004, 12:32 PM   #3 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
I had a similiar problem with my car. It ended up being something like there wasn't enough spark at 400rpms which is when the car actually fires. you might want to check your plugs or change your oil. those things worked for me and I haven't had the problem since. went to synthetic and put in better plugs.
jrhaile is offline   Reply With Quote
Old 10-30-2004, 05:30 PM   #4 (permalink)
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
mine does that a little bit too. when i first start it up cold, it complains for a second, a little sputter here and there, no biggie but kinda embarassing
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline   Reply With Quote
Old 11-01-2004, 10:05 AM   #5 (permalink)
i got a tuneup done yet the car hasnt been able to start. the sparkplugs wont spark, they wont fire! they were replaced with the tuneup. ive hered it could be the camshaft sensor? or maybe the crankshaft sensor ? any one hered of this b4? i need this car runnin asap!
1998 328I
4 Door Sedan
100% Stock
Old 11-03-2004, 12:38 AM   #6 (permalink)
blakbeauty is an unknown quantity at this point
I am no expert by far, but I work with a very knowledgeable mechanic who is helping me solve this very problem. I am hearing that the cold weather starting problem may be linked to the idle control valve sensor. DO not quote this, but the part effecting the air/fuel intake is effecting the mixture. Carbon may cause the valve to remain open or stay closed, therefore allowing more air in/more fuel in, much like a butterfly on a carb. It is my understanding that this part is easily removed by one bolt, then cleaned out by B12 Chemtool like substance, then place back on. If this does not fix it, check the hard, plasticc tubes going into the air intake for leaks. I hear these models are synonymous for this.
I just purchased my '96 328i a few months ago have literally loved it. Nothing compares to it. And the price I paid for it.....
blakbeauty is offline   Reply With Quote
Old 11-03-2004, 04:49 PM   #7 (permalink)
i just got my car back fom the garage and the problem was small and simple there was a problem with the grounding the mechanic told me. it was an electrical problem he charged me 80 cuz it took time to find it but its way better then what the dealer would of charged me
1998 328I
4 Door Sedan
100% Stock
Old 11-04-2004, 07:55 AM   #8 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
What was grounded... do you know?...
Thanks,
Les
1997 E36 M3 1990 E30 325i
Problem Starting 325ic napalm 3-Series (E36) 4 06-17-2005 04:05 PM
Sound System Problem '96 328i, gfowler 3-Series (E36) 2 02-22-2005 03:33 PM
Drivers Seat Problem 00 328i vtr1000 3-Series (E46, E90) 13 02-16-2005 04:05 PM
Diesel Starting Problem Please Help !! mrdunkleysexy 3-Series (E36) 3 08-02-2004 10:47 AM
