98 318i Brake Job Problems - BMW Forum - BimmerWerkz.com
Old 10-14-2004, 11:12 AM   #1 (permalink)
barcode252 is an unknown quantity at this point
I'm looking for a few sugestions. I'm Trying to put on new rotors and pads on my car but i cant get the calipers to compress enough to fit the pads around the rotor. It looks like the caliper may have a bit of corrosion preventing it from compressing all the way.
Is there a good way to get these compressed? Would cleaning them help and if so how would be the best way to clean them? Do i just need to get new calipers and if so where from?
Thanks for any help you can give me.
barcode252 is offline   Reply With Quote
Old 10-14-2004, 11:26 AM   #2 (permalink)
I used a c-clamp. Have you tired that?
Old 10-14-2004, 11:28 AM   #3 (permalink)
nycbmw325is is an unknown quantity at this point
[snapback]211102[/snapback]
How are you going about compressing them? Try using a scotcbrite pad and some brake cleaner to polish up the piston. a toothbrush often helps. if you see real scoring and or pitting, you will likely need to rebuild or replace the caliper. What happens is the rough surface tears the seal up and then the caliper starts to leak.. so if you can't rebuild or replace try getting some krocus cloth and polishing any of the nicks and sharp edges out ... this will hopefully save your seals form being cut. If you are not completely comfortable with doing this DO NOT MESS WITH your brakes are far to important to screw up in the hopes of saving a few dollars.
nycbmw325is is offline   Reply With Quote
Old 10-14-2004, 12:12 PM   #4 (permalink)
We were using a c-clamp to compress.
I will give a light cleaning a try i only need about 2mm to get them on there.
Thanks for the suggestions
Old 10-14-2004, 02:04 PM   #5 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
this might not work, but trying usncrewing ur master cylnder cap
xsperf is offline   Reply With Quote
Old 10-14-2004, 02:06 PM   #6 (permalink)
C-Clamp is definitely the way, possibly the only way. Buy a heavy duty one and that will definitely push the piston back into the caliper. Bashing it with a hammer won't work!
Old 10-14-2004, 03:16 PM   #7 (permalink)
[snapback]211211[/snapback]
since many of folks are concerned with cost... and plenty probably dont have a big honking C clamp... why not go out and but a tool designed expressly for this job, which cost less than ten bucks and works better than holding the old pad in place while you try to figure out if you can get the c clamp to stay put on an irregular surface? Sometimes the right tool is cheaper.. becuase a good 6 inch C clamp is at least ten bucks...
Old 10-14-2004, 03:30 PM   #8 (permalink)
Originally posted by nycbmw325is+Oct 14 2004, 02:16 PM--><div class='quotetop'>QUOTE(nycbmw325is @ Oct 14 2004, 02:16 PM)</div><div class='quotemain'><!--QuoteBegin-Autotechnica@Oct 14 2004, 01:06 PM
[snapback]211270[/snapback]
[/b][/quote]
Paid $6 CDN for my C clamp and it was a heavy duty one. C-clamps are very useful for doing a lot of things, not just brakes! Plus, it was easy to use so I don't know what would be so special about that "special tool".
Bry
Old 10-14-2004, 03:36 PM   #9 (permalink)
when I used the C-clamp to compress the piston, I did get a little bit of brake fluid to spill out the resivoir.
I don't no what would happen if the cap was so tight none could come out? I guess it could make it harder to compress the piston.
My 1994 318i has some problems itbestrider 3-Series (E36) 14 10-12-2005 10:46 AM
Rear Brake Problems nstg8 1 3-Series (E21, E30) 1 04-21-2005 06:14 AM
318i brake sensor (and other sensors) abajaj 3-Series (E46, E90) 1 05-05-2004 11:16 AM
