Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 01-20-2006, 02:16 AM   #1 (permalink)
Photos: 0
sabre40 is on a distinguished road
97 328ic convert top stuck
My wife's 97 328ic top stopped operating when I went to put it up for the day. It occured when the top lid stowed back down, the top never went to the down position after that (fwd to the latch and the aft section down to the lid). Anyone come across this and found the remedy? Does manually stowing it cause sequencing problems ?
Help!
Pensacola, FL
sabre40 is offline   Reply With Quote
Old 01-20-2006, 01:34 PM   #2 (permalink)
Canadian
Furious's Avatar
Photos: 0
does the motor sound like its working? a few times we have had similar questions... every solution has been different. i really cant help you out on this(not certain), hopefully someone will be able to give you some insite.
R.I.P Steve aka fast 6
Old 01-21-2006, 10:33 AM   #3 (permalink)
Photos: 0
The top driver....
motor works, but the fwd latch motor is not getting power to complete the top down, the top lid is down and things look in sequence, it just stops at that point. I'm hoping it's a switch but I haven't quite figured it out. I manually put the top down, does this ruin the sequencing of the system?
Pensacola, FL
Old 01-27-2006, 08:34 AM   #4 (permalink)
Photos: 0
jcy0001 is an unknown quantity at this point
hey maybe you have to reset the convertible top if so here a link i found but im kindav a newbie so read up some more coz i could be mis understanding the case heres a link tho on how to do it http://home.att.net/~ebaines/converti.htm
jcy0001 is offline   Reply With Quote
Old 01-27-2006, 07:04 PM   #5 (permalink)
topless_328's Avatar
Photos: 0
topless_328 is on a distinguished road
Could just be a relay switch that burnt out, causing the next sequence in the top-down procedure to stop. Also, i've heard, if the sensor in the rear tonue cover doesn't read that the rear is sealed, it won't complete the closing of the top.
My suggestion, try and find a convertable top place and have them take a quick look over it.
I had conv. top problems and was forced to go to the stealership and left $400 poorer for some connection that fell off the roof's motor and some tension straps....w/e
good luck
Mike
-Automotive Engineer in Training-
topless_328 is offline   Reply With Quote
Old 01-27-2006, 08:50 PM   #6 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
So by your description it sounds like you have the fully automatic top, not the style where once the top goes forward to close you still have to grab the handle and latch it the rest of the way down.. correct?
The only thing I would recommend doing is grabbing the top and moving it slightly in either direction in case that a microswitch is just hung up or not quite being activated. If it still does not close then you dont want to mess with it much or you will just do more damage.
Keep in mind that the initialization procedure that JCY posted will only work if the convertible top module hasnt stored any faults. If the module has faults it will not allow the initialization to take place.
I would not recommend taing it to a convertible top shop or upholstery shop. I have seen them do terrible work on BMWs. (not necessarily all of them) My recommendation is to take it either to the dealer or a BMW Independent shop who knows those tops well otherwise you are just going to have more problems.
Good Luck,
DT
DT
http://dtbmw.com/dt540
vB code is On
convertible top mhark 3-Series (E21, E30) 3 02-25-2007 09:50 PM
Bonnet stuck closed - please help!!! KILOCHARLIE 3-Series (E36) 0 09-26-2005 05:31 AM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 09:05 AM
Car Won't Stop! Throttle Stuck jetmax 3-Series (E36) 7 06-08-2005 03:45 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
