97 328i auto - Hard 2nd to 3rd gear shift - BMW Forum - BimmerWerkz.com
Old 10-06-2006, 12:46 PM   #1 (permalink)
Othniel13 is on a distinguished road
So here's the deal... My radiator hose fell off the radiator and dumped into my CAI. this threw a MAF code and made me pull over at which point the car would not run until I dried everything out. There is still a MAF code that needs to be cleared but the engine runs fine. Code is P0101.
When I did get the car running, the auto tranny, in any mode (D, 3, M) will shift hard any time the tranny moves from 2nd to 3rd, or from 3rd to 2nd, regardless of throttle position and even when rolling up to a stop (3rd to second). I can avoid the issue by placing the trans into M and manually shifting from 1 to 2 to N to D (or 4th) and conversly by shifting to when rolling up to a stop N then to 1 when stop completed. Problem is ONLY between 2 and 3 and trans temp does not make a difference.
I can't imagine that the coolant issue and tranny problems are related, but maybe I'm wrong? The trans was fine until I cleaned my engine with radiator fluid.
1997 328i with a 4 speed auto. I replaced the tranny fluid and filter 2 months ago and have at least 1500 miles on it trouble free. I have not checked the fluid, but wanted to see if someone else had a similar issue in the mean time.
Othniel13 is offline   Reply With Quote
Old 10-07-2006, 01:27 AM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
How many miles?
Lindsay fan club member.
Old 10-08-2006, 06:59 PM   #3 (permalink)
Mileage is just a bit over 95,000
Old 03-14-2007, 10:03 AM   #4 (permalink)
Sorry, thought I posted an update, but obviously I did not...
The problem was not the transmission, but the Mass Airflow Sensor. Seems that when my CAI inhaled large amounts of coolant, it killed the ol' MAF.
Somehow, the Autotrans on these cars will closely monitor the MAF and when there is issues, it will perform funny i.e, shift hard between gears.
So, I have been running the car for about a year with no more transmission problems since replacing the MAF.
Hard to shift in gears when is cold Slow325i 3-Series (E21, E30) 0 12-12-2005 12:08 AM
Loose Stick shield 3-Series (E21, E30) 6 09-02-2004 05:34 PM
Removing 97 540I Auto shift knob Phantomstorm 5-Series (E12,E28, E34, E39, E60) 4 03-23-2004 11:15 AM
