97 328 Thermostat - BMW Forum - BimmerWerkz.com
Old 11-04-2005, 09:39 AM   #1 (permalink)
Gkamysz is an unknown quantity at this point
97 328 Thermostat
I'll be getting around to replacing the thermostat soon. I got the parts but there is no paper gasket recommended, just an O-ring for the thermostat and a molded seal to the head. Some manuals show a paper gasket, some don't.
Anyone know for sure? It seems late models might not use the paper gasket.
Thanks.
Greg
97 328iS, Manual, Stock
Gkamysz is offline   Reply With Quote
Old 11-04-2005, 01:56 PM   #2 (permalink)
Larry Horne's Avatar
Car: 1997 328i
Larry Horne is an unknown quantity at this point
I just changed mine. For the 4th time due to housing leaks. The past 3 times the work was performed by dealer and Bimmer shop. This time I decided to do it. Once you get past the plastic its easy. I've even changed from the OEM plastic housing to aluminum.
As for the O-rings..........thats all there is. No paper, cork, neopreme etc. gasket.
I made sure everything was clean and dry. Used the OEM O-ring and molded O-ring then torqued to spec. I opted not to use any additional RTV sealant because I do not know the compatability with the OEM materials.......I would assume it to be ok, but none was recommended not there.
Lar
Larry Horne is offline   Reply With Quote
Old 11-04-2005, 02:26 PM   #3 (permalink)
Thanks. That's what I needed to know. I didn't want to have to run to the dealer in the middle of the job.
Greg
Transmission cooler Thermostat? Laker 3-Series (E36) 5 02-27-2009 01:36 PM
fan and thermostat sadubaba 3-Series (E36) 3 09-09-2005 10:42 AM
Thermostat Housing Removal E34 M20 Engine 520i tstolber 5-Series (E12,E28, E34, E39, E60) 2 05-23-2005 04:11 PM
Thermostat Installed Upside Down, Maybe? YoungExec728 3-Series (E36) 2 12-09-2004 03:15 PM
Thermostat Gasket/o-ring? Brian325i 3-Series (E36) 5 10-02-2004 02:30 PM
