97 318is Jerking - BMW Forum - BimmerWerkz.com
Old 02-14-2005, 10:25 PM   #1 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
I have a 97 318is with 107k. It is jerking when I come out of the hole and also when I am on it, shifting into 2nd. The colder it is out, when I first start the vehicle the worse it is. And no the jerking does not go away when the car is up to temp. It is just a little better when up to temp. I was told that I had a bad clucth. So I bit the bullet and had that changed. I replaced both O2 sensors, air filter, fuel filter, plugs, temp sensor, plus other parts that have nothing to do with the driveline. From time to time it throws a code P0442 which is small emmissions control leak. Don't know if this has anything to do with it? The clutch is definately not slipping when this happens because when this happens it is cruel and unusual punishment for any passengers ! Ignition? Emitions? Fuel/air delivery?Much thanks for any knowledgeable help.
polaris448 is offline   Reply With Quote
Old 02-16-2005, 06:05 PM   #2 (permalink)
polaris448's Avatar
[snapback]292088[/snapback]
Found out what the deal was on this. Just a simple tear in the air intake duct after the MAF. This was allowing unmetered air to get to engine and inturn leaning itself out and causing a stall and go. Tape will fix this until you can (I) get the part.
Old 02-16-2005, 07:41 PM   #3 (permalink)
Too Slow Monore's Avatar
Too Slow Monore is an unknown quantity at this point
thanks for the info!
Too Slow Monore is offline   Reply With Quote
Need Opinions Asap On 318is For Sale! Hoody 3-Series (E21, E30) 4 08-26-2005 03:58 AM
Price For My 318is tagerman 3-Series (E36) 7 06-22-2005 04:30 PM
318i vs 318is vs 320i Sabih 3-Series (E36) 18 08-07-2004 12:28 AM
318is vs. 325is 1985bmw325e 3-Series (E21, E30) 7 04-05-2004 09:17 PM
E30 318iS vs E36 318iS LondonE30-318iS 3-Series (E21, E30) 16 03-22-2004 01:32 PM
