96 328i stalling issues - BMW Forum - BimmerWerkz.com
Old 07-02-2010, 08:12 AM   #1 (permalink)
mannymtg's Avatar
Car: 1996 328i convertible
mannymtg is on a distinguished road
Recently the car will stall as I come to a stop. It seems to happen when the car is idling and not in gear. Any ideas/suggestions? A friend told me that it may be a clogged vent under the gas cap. If this is possible, how do I access it to find out?
mannymtg is offline   Reply With Quote
Old 09-08-2010, 04:04 PM   #2 (permalink)
TheGunslinger's Avatar
Car: 1993 BMW 325i Motorsport Coupe
TheGunslinger is on a distinguished road
Hi there, I seem to have the same problem now and then. It occurs at any temperature, cold or hot running. Have not yet found a solution either.
TheGunslinger is offline   Reply With Quote
Old 09-08-2010, 10:16 PM   #3 (permalink)
theluis's Avatar
Car: 1995 BMW 325i 5 Speed
theluis is on a distinguished road
check the intake hose that is after the mass air flow sensor for a hole or ripped strech it around a bit if it is ripped that is probably ur problem
theluis is offline   Reply With Quote
Old 09-09-2010, 12:41 AM   #4 (permalink)
Thanx theluis, I will check that out.
Old 12-03-2010, 03:39 AM   #5 (permalink)
I managed to sort out the problem by slightly increasing the idling ... no problems so far!
Old 12-06-2010, 12:33 PM   #6 (permalink)
theluis's Avatar
what are you idling at now cus as far as i kno the idle is computer controled specially for that car
Old 12-17-2010, 03:55 AM   #7 (permalink)
Idling ....
There is a small setting screw on the side of the intake manifold that I adjusted ever so slightly and it increased the idling slightly.
Old 12-21-2010, 08:55 PM   #8 (permalink)
328is_SwiSS4247 is on a distinguished road
hope im doing this right
i have the same issue everynow and then, usually when im gassing hard then stopping fast, think it has to do with the air to gas ration and a small air leak,
where exactly is that screw you speak of,
also, if you start it does it shutter a lil bit upon ignition ?
im thinking that it has to do with the same airleak
328is_SwiSS4247 is offline   Reply With Quote
Old 12-23-2010, 01:53 AM   #9 (permalink)
Gassing and stopping fast did also produce the problem for me ... but I have had no more problems since adjusting the small adjusting screw which is situated where the throttle cable is connected to the throttle arm on the top right side of the inlet manifold as viewing the motor from the front.
Stalling issues on 2005 545i BMWGB New Members Check In 5 01-03-2010 01:57 PM
E46- 1.9 single cam stalling issues Lizard-man 3-Series (E46, E90) 2 01-05-2009 03:27 PM
'95 328i Coupe stalling when revs drop after pushing clutch in keykey 3-Series (E36) 3 01-04-2009 02:00 PM
Driver's Window Issues 98' 328i Conv kauyon1 3-Series (E36) 0 10-30-2008 02:59 PM
97 328i On Board Computer Issues richietherocket 3-Series (E36) 2 02-27-2005 09:06 AM
