95_325is valve train question - BMW Forum - BimmerWerkz.com
Old 02-26-2009, 04:29 PM   #1 (permalink)
der_goat is on a distinguished road
Question 95_325is valve train question
I'm wondering if the valve train in this vehicle's engine is of the interference type. It's a friend's car, and he had some issues with the ECM and after changing that out, the car still wouldn't fire off. He cranked it and cranked it, but now, there's 0 compression. I'm hoping it only jumped time and all will be well with a new chain, tensioner, and guides. However, I would hate to have to tell him that he's got some bent valves and I'll need to rework the head. I'm just recently getting into european cars, so any help wouold be greatly appreciated!
der_goat is offline   Reply With Quote
Old 02-26-2009, 07:28 PM   #2 (permalink)
yep, it is the interference type.
silversled is offline   Reply With Quote
Old 02-26-2009, 11:44 PM   #3 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
im guessing youve already done a compression check and got 0 compression? if you havent go ahead and do that and post of what numbers you are getting... if you are getting low or no numbers then i'd try the oil in the cylinder check... put about an ounce of oil in the cylinder and then check the compression again, if it gets compression then its piston ring thats gone... if its not then its the valves not sealing... if you find that you are getting compression without the oil then check for fuel and spark... those are the only other things that could be wrong with it... im hoping it ends up you all passed over a blown fuel pump fuse or something... if it is that, replace the fuse and the fuel filter because that ussually means the pump was having to work real hard to pump the fuel and blew the fuse... on the other hand pray its not ignition... thats one field i cant stand when it goes wrong...
Old 02-27-2009, 01:49 PM   #4 (permalink)
Thumbs up nothin...
Thanks, silversled and saltshaker, the guy said he'd heard rattling from the timing cover before the ecm took a crap. He cranked it and cranked it then heard a pop and then spun fast. I've not done an official compression test, but I have experienced the bent valves not sealing. It just sits and spins over with no resistance to the starter. Looks like I'll be playin with the head. Any tips on what to watch out for? Special tools? Or is it pretty straight-forward?
Old 02-27-2009, 09:07 PM   #5 (permalink)
no, no magic, just gonna have to pull the head and take it from there. hopefully the valves didn't punch any holes in the piston crowns and do too much damage to the head itself. could go anywhere from a simple valve job, with new valves as required, to a complete engine rebuild ($700-$5000) depending on what you find out once you get in there. good luck on that
E34 V8 Valve Adjustment Question 94BMW530i 5-Series (E12,E28, E34, E39, E60) 7 10-10-2007 02:54 PM
Question about Valve Cover Gasket ????? 325IConvertible 3-Series (E36) 8 11-20-2006 10:48 PM
train dodging Ivan Video Vault 6 08-23-2006 05:33 AM
94 318is Drive Train set OEM Parts 2 07-29-2005 02:55 PM
Valve Question mrclean 1,6,7,8 - Series and Mini Cooper 2 06-16-2005 09:29 AM
