Originally posted by Brian3251+Jan 14 2005, 05:46 PM--><div class='quotetop'>QUOTE(Brian3251 @ Jan 14 2005, 05:46 PM)</div><div class='quotemain'><!--QuoteBegin-93 325i@Jan 14 2005, 05:26 PM easy test to try is pull of the bottom backseat cushion and turn the ignition on and listen for the fuel pump. You should be able to hear it. It's the one on the passenger side. This way you can eliminate this as your cause.. [snapback]271681[/snapback] |
my backseat bootom is one piece how does it come out.I had a friend earlier liston for it at the fill hole and he could not hear nothing but some gugerling not the correct word for what iam trying to say !
[snapback]271690[/snapback]
[/b][/quote]
got the seat out and with the ignition on ,heard nothing ? maybe iam just getting enough gas at first crank to fire the engine and get the plugs wet but not to keep it running and starting.How hard are these fuel pumps to replace if that is the case ?
