95 318i locking issues - BMW Forum - BimmerWerkz.com
Old 11-20-2012, 08:11 AM   #1 (permalink)
Car: 1995 BMW 318i sedan
edec is on a distinguished road
i just bought a 1995 BMW 318i Sedan. I'm having an issue with the locks. When I unlock the driver side door only that door unlocks while the other 3 don't. I can't unlock the passenger side with the key. I saw that the fuse for central locking was blown so I replaced it. That didn't solve the problem. Also, the trunk wont lock, I've used the key to try to manually lock it but it wont work either. Any help would be greatly appreciated.
edec is offline   Reply With Quote
Old 11-20-2012, 09:50 AM   #2 (permalink)
A first thought is that you're looking for a bit of worn wiring that's causing a short to the car's body work.
Old 11-23-2012, 08:03 PM   #3 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
You probably have a problem with your door actuator. Its a little electronic box that converts an electrical signal into a mechanical action. The actuators have little micro switches that over time go bad. When one fails, it causes issues with the whole central locking system. The actual central locking Module, known as th ZKE is located behind the glovebox.
A replacement actuator is $75 at Bimmerspecialist.com
Click HERE to see my E36 Blog
95 318i Emission Lambda Control issues iamdonjuan 3-Series (E36) 4 12-21-2012 08:40 AM
1995 318i issues! Ashley318i 3-Series (E36) 3 06-18-2012 03:58 PM
BMW E30 318i central locking fault raduburcea 3-Series (E36) 2 03-04-2012 10:24 AM
Starting issues on 85' 318i tyler.speer 3-Series (E21, E30) 2 06-07-2007 05:00 PM
96 318i AC Issues? BMWBoi 3-Series (E36) 1 07-14-2004 12:20 PM
