| 95 318i - How to remove clutch master cylinder? I've got the master cylinder unbolted but how do I get it out? The end of the master cylinder that goes through the firewall is still connected to the line to the slave. Do I pull on the master cylinder to bring the connector to the slave line inside the car to disconnect it from the inside or do I try to disconnect it from within the engine compartment? And how do I disconnect the hose between the master and the reservoir? I've disconnected the hose from the reservoir but it is still connected to the master. Any help would be appreciated. |
