94 325is Problems - BMW Forum - BimmerWerkz.com
Old 10-17-2004, 05:48 PM   #1 (permalink)
sre2114 is an unknown quantity at this point
I just got a 94 325iS and I was wondering how many problems are too many problems? Right now i have 6: brake light circuit, rattle driver side rear, ac/heater dials dont lite, windows wont go up unless you overide the safety fearture, passenger seat doesnt go up, and the automatic temperature control doesnt seem to work right. I was just wondering if this amount of problems is normal for a 10 year old BMW? Is it worth it to fix the problems and keep the car or should i return it? Thanks
sre2114 is offline   Reply With Quote
Old 10-17-2004, 05:58 PM   #2 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
how much did u pay for it?
xsperf is offline   Reply With Quote
Old 10-17-2004, 06:01 PM   #3 (permalink)
the car cost $6900 and then after everything like the registration and tax it was $7500
Old 10-17-2004, 06:16 PM   #4 (permalink)
Brian325i is an unknown quantity at this point
All those problems seem relatively small and I think that's only slighty worse than normal. The brake light circuit should be easy to replace, the rattle is probably bad rear shock mounts, dead bulb in your climate control panel, not sure about the windows, the motor in your passenger seat is probably bad or a bad connection, and the automatic temp control is pretty common not to work on e36's. I know that mine doesn't work right but I never use it so it doesn't bother me. Again, it IS a 10 year old car so there's bound to be some small problems. If you got it from a dealer you could probably get them to fix those things for free. How many miles do you have on it?
Brian325i is offline   Reply With Quote
Old 10-17-2004, 06:25 PM   #5 (permalink)
it has 130000 and we got it like late august. I dont know if I want the dealer looking at it. Its been in there like 4 times to fix the Brake Light Circuit which comes on and off at random. The first time they didnt fix it. The second time they said we couldnt get it to fail so we did nothing. The third time same thing as the second, and the fourth it was in for ABS light and the brake light circuit and they replaced the brake master cylinder and said that should fix both, well it didnt. and the scary part we have told them to replace the brake light switch and they havent.
Old 10-17-2004, 06:34 PM   #6 (permalink)
/Banned
xsperf's Avatar
no freagin way.. thas way too much dude
Old 10-17-2004, 06:48 PM   #7 (permalink)
way too much money? most of the cars around here are in that price range. Why how much should I expect to pay.
Old 10-17-2004, 06:51 PM   #8 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
That's terrible! Find a competent independent BMW mechanic. Did they charge you for the brake cylinder? If so, you should complain and get your money back. I would recommend you replace the brake light switch yourself. I'm kind of a lardass, but was still able to do it (small space under there). There is a DIY on Pelican Auto Parts website.
-Alternatively-- any mechanic could do it. The other problems: same as what the others have said. So , no further help there. The auto climate control on my car was replaced just before I bought it, at 45K. It's a 98 .
Welcome to BMW ownership-it gets better
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars.
theogill is offline   Reply With Quote
Old 10-17-2004, 07:02 PM   #9 (permalink)
yeah its pretty sad, and no they didnt charge me for the brake cylender. Also i really dont want to replace it myself because its their problem that they said they would fix before we even bought the car in august and they havent fixed it. So im going to make their life miserable and then replace it if they dont in a couple months and bill them for my labor hopefully.
Old 10-17-2004, 07:32 PM   #10 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
I also got my car with lots of problems. Needed all new shocks and mounts, driver side window was broken, valve cover gasket and oil pan gasket needed to be replaced, and new control arm bushings. Some other things. I got the car about a month ago now. Started repairs early oct. Its a '94 with 135 miles on it. The guy sold it to me for 6K and I have done around 2K in parts cost and some shop repairs. I guess it all depends it you have money and time. But to me, it was worth it.
Current status: broke, but happy. lol.
theruss1an1 is offline   Reply With Quote
Old 10-17-2004, 07:41 PM   #11 (permalink)
I didn't realize you bought the car from them, or did you?. If so, That's even more outrageous! They should take care of that--it's such a simple thing. AND the other problems. Give em HELL. It might be worth becoming a member of the BMWCCA, because then they might think you're "linked" with the greater BMW world and will spill the beans about their incompetence.
Old 10-17-2004, 07:58 PM   #12 (permalink)
well it isnt a BMW dealership its some little place in upstate NY called Majestic Auto. But yeah i bought the car from them and we are noticing all these problems as we go along. Its really sort of dissappointing. Also the rattle isnt a rattle its like plastic on plastic sort of a rub and its coming from where the rear speaker is right above the seat.
Old 10-17-2004, 09:52 PM   #13 (permalink)
I'd get the auto climate control fixed, and the window issue resolved. I doubt they'll take care of everything, and those are potentially the more expensive. As for the rattle, not sure. SOunds like you might just need to jam something in there to stop the friction. Overall, these issues sound pretty benign. As long as the car drives and runs well, the other stuff will get sorted sooner or later. Also, it makes sense that they haven't replaced the brake light switch--they've probably never heard of this common problem on e36 beemers.
oh well
Old 10-17-2004, 10:02 PM   #14 (permalink)
Speedy-325is's Avatar
take it back, get something that works completely. i got mine for 5500, and they fixed all the little problems before they let me drive away. no joking, if they are giving you the runaround, then what is wrong with the car that they dont want to fix...what is going to be your first BIG problem. as said before, find an indipendant euro car shop and pay the 60 bucks to have them find all the problems, figure out whats gonna go next, then decide what to do. dont trust the dealer mechanics...those guys work and speak directly off of a script..
good luck
Mark
Old 10-19-2004, 04:15 PM   #15 (permalink)
SemiPerfect is an unknown quantity at this point
Originally posted by Speedy-325is@Oct 17 2004, 10:02 PM
take it back, get something that works completely.* i got mine for 5500, and they fixed all the little problems before they let me drive away.* no joking, if they are giving you the runaround, then what is wrong with the car that they dont want to fix...what is going to be your first BIG problem.* as said before, find an indipendant euro car shop and pay the 60 bucks to have them find all the problems, figure out whats gonna go next, then decide what to do.* dont trust the dealer mechanics...those guys work and speak directly off of a script..
good luck
Mark
[snapback]213099[/snapback]
Bought a 1995 325i sedan, outside and inside of car in almost perfect condition.. aside from needing a wash.. I got it for $4500 and it has 130 K on it.. Here is a break down of the problems I had fixed on it:
exhaust system replaced: $344
odometer intemittenly on/off, clock not working:replaced whole cluster for $350
(note: this also fixed clock)
tramsmission fluid had to be changed: $180 (includes filter/labor)
water pump needed to be reaplced: $79
rear brakes: $169 + $12 to replace brake sensor
total labor charge: $300
So after repairs, taxes, and cost of car, I spent around $6200-6300.. And everything on the car works, besides what was mentioned.. Plus it looks darn good.. I'll post pics when I get it all cleaned up..
$6900 seems a little high for a 94 2 DR 325is, I know in Dallas or Houston, you can get them all day long for around $4500-6000 easy.. I came across a 93 325IS w/ 144 K, jet black, for $5500, and it was in great condition..
Go check out Autotrader.com, you'll be able to figure out what the market is like in your area and in surrounding areas..
By the way, my car has a value of around $6500-7000 according to edmunds.com
The 325IS 94 the person speaks of is valued at around $4500-5000 if bought by private part.. And would sell for $6500 at a dealer's lot.. I had to list this car as AVERAGE condition b/c of some of the mechanical faults it had and it lowered it's value by $1200-1600 depending on if sold privately or by dealer.. Higher if by dealer.
SemiPerfect is offline   Reply With Quote
Starter Problems 325is e36surge 3-Series (E36) 6 05-23-2005 04:03 PM
325is Problems NyteRyda 3-Series (E36) 8 10-07-2004 12:59 AM
1992 325is transmission + electronic problems danyal711 3-Series (E36) 1 08-13-2004 10:31 PM
Common Problems on 92' 325is Bimmeracin 3-Series (E36) 4 07-23-2004 10:37 AM
