'94 325i overheating help please:) - BMW Forum - BimmerWerkz.com
Old 02-16-2007, 06:18 PM   #1 (permalink)
angilfyre is on a distinguished road
Hi,
I have a 1994 325i and the engine keeps overheating. I have replaced the radiator, expansion tank, expansion tank cap, lower and upper radiator hoses, overflow hose, sensor attached to expansion tank, and thermostat (88 degree). I also use bmw coolant (50/50 combination of water/antifreeze). The only other thing i can think of on the coolant system is the water pump. Could it be anything else? Thanks
angilfyre is offline   Reply With Quote
Old 02-17-2007, 01:28 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
-water pump on a 1994 was not metal it a very good possiblity that its bad.
-also you might have replaced the problem but didnt bleed the system properly leaving an air pocket in the engine.
Old 02-17-2007, 01:53 AM   #3 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
Crack in block/head.. too.
But make sure its bled correctly first.
Old 02-17-2007, 10:32 PM   #4 (permalink)
EricBimmer22's Avatar
Car: 95 BMW 325i
EricBimmer22 is on a distinguished road
I had the same problem with my 95 325i and it turned out that I had a bad head gasket. I had a leak down test performed before I started replacing all the parts that you already have completed. Did a mechanic suggest that you replace all those parts? I mean it never hurts to replace a $12 thermostat. Also I guess a minor possibility could be the fan clutch too.
Fuhgettaboutit
EricBimmer22 is offline   Reply With Quote
Old 02-23-2007, 08:50 AM   #5 (permalink)
phathaway is an unknown quantity at this point
Probably the water pump, I had the same problem with my 94. From what Ive read the water pumps tend to fail sometime after 100,000 miles. I talked to a guy at the BMW dealer near me and he was amazed my car last 140,000 miles before it failed.
phathaway is offline   Reply With Quote
Old 02-23-2007, 08:59 PM   #6 (permalink)
hi..
I got the water pump replaced and it still ran hot. It turns out that it is the cylinder head. I am not going to get it milled / machined. Instead I plan on buying a refurbished or new engine. Does anyone have any advice on the refurbished? I have not obtained a price on refurbished yet, but a new is 7k. Thanks for any advice! =)
93 325i overheating! Insane93E36 3-Series (E36) 9 05-02-2012 12:33 AM
overheating e36 325i coupe 1994 m reg rizla 3-Series (E36) 2 09-03-2004 11:22 AM
