Originally posted by mrkbik@Jan 25 2005, 10:06 AM It's probably not bent, that would cause it to stick every time wouldn't it? [snapback]278759[/snapback] |
you should also take a look on the trottle body at the intake manifold..
it is easier for dust and dirt to get into the moving mechanism of the accelerator on the engine compartment that inside the car..
when this happens, normally what happens is that the trottle body has some oil dirt on it//
so it is a good time to get that can of trottle body cleaner and take the trottle ou and clean and degrese all the mechanism, then reaselmble using fresh lubrication..
also is doing the above procedure, get new gastket.
But, give it a try first inside car, i really dont think the problem is in there, and since you say is not clicking, then most likely the accelerator mechanis on the engin compartment needs some cleaning and lubrication..
have a good one.
