'94 318is Air Filter Replacement Help... - BMW Forum - BimmerWerkz.com
Old 03-20-2005, 10:58 PM   #1 (permalink)
ultraviolet353 is an unknown quantity at this point
I need to replace the air filter for my '94 318is. Whjer is it located--is it easy to do? Any DIY links for this? What brand do you recommend?
ultraviolet353 is offline   Reply With Quote
Old 03-20-2005, 11:20 PM   #2 (permalink)
xxxbimmer's Avatar
xxxbimmer is an unknown quantity at this point
Send a message via AIM to xxxbimmer
i would prob go w k&n for the air filter
REALLY EASY TO DO.........just pop the top of the air box out and put the new one in
<img src='http://img.photobucket.com/albums/v496/pwr2thenike/asfasdf.jpg' border='0' alt='user posted image' />
xxxbimmer is offline   Reply With Quote
Old 03-21-2005, 12:07 AM   #3 (permalink)
Ricky is an unknown quantity at this point
Yeah, it's really easy. Look under the hood on the driver side,
next to the radiator. There are several clips which hold down the
top, you simply pop them loose, remove the top, take the filter
out, then drop the new one in. You may have to use a little muscle,
but none the less, it's a fairly easy operation. As far as filter types,
K & N is OK, but it is my belief that if you change your filter every
6000 miles, you should be allright. Most air restriction
is at the air intake tube and throttle body, so it is a matter of how
often you change your filter that counts. Bigger pores in the filter
means more dirt into the combustion chamber, at
least that's my opinion.
&quot;Obstacles are what you see when you lose sight of your goal&quot;
Ricky is offline   Reply With Quote
Old 03-21-2005, 01:46 AM   #4 (permalink)
Boxbrownie's Avatar
Boxbrownie is an unknown quantity at this point
Send a message via AIM to Boxbrownie Send a message via MSN to Boxbrownie
Unless your not going to change your filter for another 100,000 miles stick to the original BMW paper type, a clean paper element is the sensible choice.
Best regards David
Boxbrownie is offline   Reply With Quote
Old 03-21-2005, 06:52 AM   #5 (permalink)
Hootie361 is an unknown quantity at this point
Send a message via AIM to Hootie361
Don't believe any rumors regarding the K&N, or similar, air filters. They are performance filters, comprised of materials that breath more efficiently and STILL restrict the passage of particulates into the air stream. I have yet to talk to one person who noted a K&N air filter wrecked their engine. I, personally, have switched to the K&N over the stock for my bimmer and noticed a slight improvement in the way the engine sounds/performs. Note though, that K&N filters still require cleaning once a year.
If you're looking for the cabin air filter to your A/C system, check in the rear of the engine compartment, just below the windshield. I've also heard some of these cabin air filters can be located behind the glove compartment in the passenger cabin.
Your Lane ------>
Hootie361 is offline   Reply With Quote
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Help W/ Fuel Filter Replacement netdude 3-Series (E36) 2 03-07-2005 11:25 AM
need advice on $750 audio overhaul '94 318is ultraviolet353 Audio and Electronics 24 08-17-2004 08:36 PM
'94 318is: brake light & fog light question ultraviolet353 3-Series (E36) 2 08-14-2004 01:46 AM
