93 325i overheating! - BMW Forum - BimmerWerkz.com
Old 10-24-2006, 09:34 PM   #1 (permalink)
Car: 1993/BMW/325i
Insane93E36 is on a distinguished road
Send a message via Yahoo to Insane93E36
Just got my 93 325i and i had a huge problem a week after i got it. First the Coolant recovery tank exploded on it and i replaced it with a new unit from BMW. Then the car started overheating like crazy, never let it hit the red and stopped for it to cool down. So i dug further and ended up replacing the thermostat, the old one came out in 5 peices it was trashed. Still the problem persisted this time it blew a hose back on the fire wall at the heater control valve. Replaced the heater control valve with yet another new one from BMW. So far a replaced recovery tank, thermostat and heater control valve. I have bled the system for air properly and still the car will over heat, i am lost on this one, any ideas? The head gasket is fine and there are no visible leaks anywhere on the motor!
Insane93E36 is offline   Reply With Quote
Old 10-24-2006, 10:58 PM   #2 (permalink)
WarNox's Avatar
hey, its probably the water pump.
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 10-25-2006, 09:28 AM   #3 (permalink)
Car: 1993/BMW/325i
new water pump also, was put on 2 days before purchase, this is all just drivin me nutz, but thanx i'll look back into it!
Old 10-25-2006, 11:34 AM   #4 (permalink)
rborak318iS's Avatar
rborak318iS is an unknown quantity at this point
Check out the radiator, though you said it isnt leaking it may be worth looking into. They can go bad or get cracked.
rborak318iS is offline   Reply With Quote
Old 10-25-2006, 02:50 PM   #5 (permalink)
jnstrcklnd's Avatar
jnstrcklnd is just really nicejnstrcklnd is just really nicejnstrcklnd is just really nicejnstrcklnd is just really nice
You said the thermostat was in 5 peoces. Are you sure you got them all out? Could be plugging something up and causing back pressure.
jnstrcklnd is offline   Reply With Quote
Old 10-25-2006, 04:32 PM   #6 (permalink)
WarNox's Avatar
hmm ok then.
when you just leave the car running does your fan come on after a while? the one that comes out of your waterpump? it always spins but when it gets hot it should spin much faster.
Old 10-27-2006, 08:56 PM   #7 (permalink)
Car: 1993/BMW/325i
welli think we figured it out, after many exhausting hours of trouble shooting and testing, the problem was an air pocket in the system that we were unable to get during conventional bleeding of the cooling system, so we solved the problem by vacuming the system and it seems to be running fine now, no more overheating, no more pressure, just smooth running as it should be. Thanx for all of the suggestions and it was helpful.
Tony
Old 01-28-2012, 12:51 AM   #8 (permalink)
peluso1228 is on a distinguished road
hi tony, my name is juan \ i have the exact problem , expantion tank explote , i did replace my termosthat was bad ,thats why blow my tank out, new coolant , bleeding also , still overheating....how you vacuum the system ?, please let me know
peluso1228 is offline   Reply With Quote
Old 05-01-2012, 02:34 PM   #9 (permalink)
DickDonlevy is on a distinguished road
Bleeding the air on an E36 is notoriously difficult.
The last time I did it it took about 4 hours, jacking up different corners of the car in turn to move the air pockets along. Wish I'd have read your post earlier!
DickDonlevy is offline   Reply With Quote
Old 05-02-2012, 12:33 AM   #10 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Dick this thread was 6 years old.
Click HERE to see my E36 Blog
overheating e36 325i coupe 1994 m reg rizla 3-Series (E36) 2 09-03-2004 11:22 AM
VIN check please E30 giz Bimmer Talk/Motorsports Talk 6 07-28-2004 06:02 PM
