93 325i Conv. Starting Problem - BMW Forum - BimmerWerkz.com
Old 03-13-2005, 01:20 PM   #1 (permalink)
JasonGrant is an unknown quantity at this point
Hi,
I was wondering if i could get some advice, my wife has a '93 325i Conv. Auto the other day it refused to start - basically the engine would turn over as normal however it wouldn't catch, eventually after about 60 - 90 seconds and holding the accelerator down it started.
The same problem happened again today - car would turn over, but wouldn't start until the Accelerator fully depressed and the enine turned over for about 60 seconds.
Any ideas - my initial idea would be fuel pump or relay but I haven't yet done any on car diagnosis.
Thanks
Jason
JasonGrant is offline   Reply With Quote
Old 03-15-2005, 07:23 PM   #2 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
i'm not great at this stuff yet, or even good, but i might be able to help you think up a list of things to check.
-you might check the fuel filter
-sparkplugs
-airintake (make sure its not filthy or clogged)
-starter
those are just some basics that came to mind, may not help alot, but it may eliminate a few. sorry i can't be any more help than that, just thought i would try since no one else has stepped up to the plate yet.
guys, help him out cause i sure don't know what it is. GOOD LUCK.
kyle_baker is offline   Reply With Quote
Old 03-15-2005, 07:25 PM   #3 (permalink)
RIBEMR26's Avatar
Sounds like maybe a fuel injection problem...run a bottle of fuel injector cleaner through and see if it helps.
Clear Corners and Sidemarkers
Old 03-17-2005, 10:15 AM   #4 (permalink)
bmw4life is an unknown quantity at this point
jason you have a 93 325ic right.... is it the E30 body or E36?
bmw4life is offline   Reply With Quote
Just Bought My 92 325i Now I Have A Cd Problem gothbrooks Audio and Electronics 5 06-12-2005 04:49 PM
1992 325i starting problem 1992_325i 3-Series (E36) 4 09-27-2004 12:09 PM
Non starting 325i Alex325i 3-Series (E21, E30) 17 09-15-2004 08:19 PM
Starting Problem Bighead318i 3-Series (E21, E30) 9 08-25-2004 11:21 AM
Diesel Starting Problem Please Help !! mrdunkleysexy 3-Series (E36) 3 08-02-2004 10:47 AM
