92 325is noob needs tech help - BMW Forum - BimmerWerkz.com
Old 03-04-2004, 08:58 AM   #1 (permalink)
miatawnt2b is an unknown quantity at this point
Hey All,
I just picked up a 92 325is for a great price. This is my first BMW, and I had some questions about mechanical oddities.
First, The OBC says to check coolant level, when I did it was indeed full. After some reading I suspect the float is gummed up or the switch is bad... easy enough fix.
Second The Temp gauge is all over the place. When on the highway, the gauge is steady at about the 10:30 position hovering right around the first line. Normal town driving the guage will come up to half, sometimes a little past half. Does this sound normal? I plan on doing the fan mod and cleaning up the float this weekend along with a new water pump.
Third, after driving with lights on, the OBC says Tail Light Failure. Reading tells me this is probably incorrect bulbs.
Last and most worrysome to me is a misfire under load, usually under 2500RPM. I replaced the plugs yesterday, but the miss is still there... seems to miss only after 10 minutes of driving. Engine cold, it runs fine. I am leaning toward coil packs, but have no way to verify which one is bad. Can someone help me out with the diagnostic? I doubt it's O2 sensor, but it probably needs changed anyhow. Is the BMW O2 sensor narrow range or wide range? 1, 3, or 4 wire?
And I would also like to check the ECM codes. What's the procedure for a 92? Build date is 2/92.
I do have a Bentley's manual on order.
Thanks,
Jim
miatawnt2b is offline   Reply With Quote
Old 03-04-2004, 10:34 AM   #2 (permalink)
Laxiepoo's Avatar
Laxiepoo is an unknown quantity at this point
My "Check Coolant Level" was on intermitently last week, but it was due for a service. After the serivce light reset, the warning went away.
I had a "Brake Light Failure" warning too, and got the bulb replaced for cheap.
Congrats on the purchase. I'm a complete newbie here, but I learn fast. I have a 92 325is also. How many miles on yours?
Laxiepoo is offline   Reply With Quote
Old 03-04-2004, 10:45 PM   #3 (permalink)
Defector
El Presidente's Avatar
This is the procedure for reading codes and a list of what each means.
http://www.europeantransmissions.com/Bulle....BMW/bmwcod.pdf
Old 03-09-2004, 09:48 PM   #4 (permalink)
Cool.
The misfire was a coil, and I did the water pump and fan mod this past weekend. So far this car has been very easy to work on. Found a thermostat blown apart, and pieces in the water pump. That was the gauge problem. Cleaned up the coolant float and fixed the problem with "Check Coolant." Control arm bushings are this weekend, and they look pretty easy too. I also need to pull the wheels and check things in the brake area. It's hard when you can only borrow a garage. The car has 120,000 on it.
Old 03-09-2004, 10:07 PM   #5 (permalink)
bubba is an unknown quantity at this point
Congrats on your purchase...I have a '92 325is also. Had the same check coolant and brake light problems..same fixs.. There's more info in the faqs section on
common problems http://www.bmw-forums.com/forum/inde...showtopic=1434
Great car and I've had no major problems what so ever...Enjoy the ride....
bubba is offline   Reply With Quote
E30 325is Vs. M3 Suspension Points XtremeDream 3-Series (E21, E30) 3 04-07-2005 04:06 PM
Parted Out 1990 BMW 325is morti86 Classifieds Sell & Buy 6 11-28-2004 07:09 PM
e30 325e VS e36 325is catalyst. 3-Series (E21, E30) 10 08-05-2004 11:40 AM
94 325is mod to m3 body kit with m badge? bmw_m3power 3-Series (E36) 20 10-09-2003 05:08 PM
