BMW Forum - BimmerWerkz.com
BMW Forum - BimmerWerkz.com (http://www.bimmerwerkz.com/forum/)
-   3-Series (E36) (http://www.bimmerwerkz.com/forum/3-series-e36/)
-   -   M50B25 idle problem (http://www.bimmerwerkz.com/forum/3-series-e36/m50b25-idle-problem-76881.html)
Krotes 11-13-2012 01:32 AM
M50B25 idle problem
I've had this problem since I bought the car. When I start the car cold it runs idle pretty well and stable and doesn't smoke, but after few minutes rpm goes down a bit and it starts running so bad that the whole car is shaking and it's smoking quite a lot too...so it seems to start running on rich for some reason? So far I've changed new bosch lambda, new sparkplugs, new camshaft position sensor, checked all intake hoses for any cracks and leaks, cleaned icv and tested that it's working and also tested ignition. Still no any diffirence. Got any ideas what to do next?
ElTonyo69 11-15-2012 11:55 PM
I had a very rich and rough idle ad my problem ended up being the VANOS not being adjusted correctly.
Krotes 11-16-2012 02:38 PM
I got non-vanos, so can't be that.
Ivan413 11-18-2012 08:26 PM
My e36 had an idle problem. If you haven't cleaned your MAF sensor, so and if problem continues its most likely you o2 sensor causing the problem
Lord Vader 11-23-2012 09:18 PM
Bingo. This is most likley the problem. A bad O2 sensor can cause a host of issues as the car doesnt know what the air fuel mixture is and cant adjust properly. Bad idling and running rich is quite common.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
