BMW Forum - BimmerWerkz.com
BMW Forum - BimmerWerkz.com (http://www.bimmerwerkz.com/forum/)
-   3-Series (E36) (http://www.bimmerwerkz.com/forum/3-series-e36/)
-   -   Transmisson warning light (http://www.bimmerwerkz.com/forum/3-series-e36/transmisson-warning-light-75412.html)
mincohome 02-02-2012 09:18 PM
I have a 1996 328I automatic transmission older drives good but sometimes when I turn it off the transmission wraning light will come on and then the transmission is in safe mode. I can turn the car off and wait a few seconds turn it back on and it will go off and drive fine. what do you think it is any ideas.
Jack Dabsy 02-03-2012 12:56 PM
As a calculated guess, I would change the tranny oil and maybe change or replace tranny filter. HTH
mincohome 02-06-2012 08:54 AM
life time transmission
my transmission warning light comes on I want to change the fluid and possibly the filter to see if it corrects the problem light comes on I turn the car off wait ten seconds turn it back on it resets and operated fine. what about eh life time fluid I do have 200,000 miles on this vehicle and think it would not hurt to change the fluid please advise
Lord Vader 02-06-2012 10:07 AM
Well you have an OBD-II car so you could take it to an auto parts store or mechanic and have the system scanned for trouble codes. That would give you an idea of if the car believes theirs a fault in the system.
I'm an advocate of changing the trannsmission fluid. Everyone gets confused by BMW's statement of "lifetime fluid". However that statement is meant to be the lifetime of the trannsmission. So if the tranny lasts 100,00 kim then that was its lifetime. However, ALL synthetic fluids break down over time. And because of this they should be changed. Some people report better shifts after having done it so their can be a benifit.
PelicanParts.com has a transmission filter and gasket kit available. All you need is the Trannsmission fluid. For that most people recommend Redline fluid.
mincohome 02-06-2012 10:26 AM
Yes I agree with you on the fluid and yes i think I will take it to get the error code read to determine if it is something more serious. I am just concened about the type of fluid to replace it with. It does not seam serious at all just eh sensors or computer telling me to do some type of service
Thank you
Jeff328i 11-15-2012 01:01 PM
I too am having the tranny light come on and the trans go in to limp mode. Decidedly came to to BimmerWerkz to aquire wisdom and knowledge. So does anyone know how this saga ended?
Lord Vader 11-23-2012 09:25 PM
The transmission goes into limp mode to protect itself when a fault is detected. You should go hav the OBD system scanned for trouble codes. The codes will give you a code idea of what is wrong, and we can help you better from their.
Jeff328i 11-26-2012 02:57 PM
I did check the code with my reader and there were more than a few; Fuel Trim, Cam Position Sensor, MAF, TPS. So I thought I'd put the old MAF back in for a reference point. Now I still get the Fuel Trim, Cam Position Sensor, but the tranny doesn't fail, nor the MAF, TPS. Seems odd, No? The OBD system seems to be so intertwined with all of the feedback sources one can hardly ascertain the root cause. Quite the quandary!
Lord Vader 12-02-2012 03:34 AM
If your getting CPS and TPS codes i would clean the sensor with contact cleaner and see if that clears the code. If not, replace the sensor.
With the car running, unplug the MAF. If the idle gets better, then the MAF is faulty.
rajendersingh90 12-10-2012 01:57 AM
maybe i am not sure but that problem could be related with the battery of your car? there is no harm in checking up the battery of yours here...
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
